The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
- APC NetShelter SX Enclosure with Sides - rack - 42U
- Product Type
- Rack
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 42U
- 60 cm x 107 cm x 199 cm
- 125 kg
- Wheels, keyed alike, adjustable depth
- 5-year warranty
- Product Type
- Rack
- Rack Size
- 19"
- 42U
- 60 cm
- 107 cm
- 199 cm
- 125 kg
- Black
- Weight Limit
- 1364 kg
- Mounting Kit
- Included
- EIA-310-D, UL 60950, IEC 60529 IP20, RoHS, BAA
- TAA Compliant
- Limited warranty: parts and labour - 5 years
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £199.36 |
APC 1U Vertical Cable Organiser | In Stock | £121.12 |
APC 1U Horizontal Cable Organiser | In Stock | £53.59 |
APC Smart-UPS SC 450VA 1U | In Stock | £277.11 |
APC Netshelter heavy duty shelf | In Stock | £141.84 |
APC - rack cable guide - 1U | In Stock | £50.87 |
APC Rackmount Rail Kit | In Stock | £90.24 |
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £203.79 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £294.53 |
APC Smart-UPS 5000VA | In Stock | £3,642.91 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £321.56 |
APC Smart-UPS RT 20kVA RM 230V | In Stock | £12,122.39 |
APC Equipment Support Rails for 600mm Wide Enclosure | In Stock | £72.21 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £284.90 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,174.49 |
APC Cable Managers (Qty 10) | In Stock | £34.52 |
APC 2G Power distribution strip | In Stock | £642.31 |
APC Rack PDU 2G METERED ZEROU | In Stock | £673.80 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V | In Stock | £2,335.21 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card | In Stock | £2,657.54 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £962.02 |
APC 19" Rack LCD Console | In Stock | £1,379.84 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £80.86 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £65.99 |
APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U | In Stock | £1,446.42 |
APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA | In Stock | £1,901.11 |
APC 1U Blanking Panel Kit | In Stock | £33.92 |
APC Smart-UPS SRT UPS 5000 Watt Lead Acid | In Stock | £4,202.92 |
APC Smart-UPS 1500VA LCD RM 1U 230V | In Stock | £964.76 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £55.89 |
APC Smart-UPS SRT 6000VA RM 230V | In Stock | £4,799.17 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £47.66 |
APC Smart-UPS SRT 8000VA RM 230V | In Stock | £6,122.73 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £69.00 |
APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V | In Stock | £2,357.85 |
APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net | In Stock | £1,622.34 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £630.78 |
APC Smart-UPS SRT 2200VA RM 230V | In Stock | £1,760.85 |
APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid | In Stock | £2,767.52 |
APC Metered Rack PDU | In Stock | £838.72 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,174.60 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £739.43 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £263.52 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £59.64 |
APC Smart-UPS SRT 10000VA RM 230V | In Stock | £7,393.08 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £665.61 |
APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) | In Stock | £597.13 |
APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) | In Stock | £713.02 |
APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) | In Stock | £893.27 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,245.58 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £157.34 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,270.23 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £82.70 |
APC Smart UPS 2200VA LCD RM 2U 230 | In Stock | £1,515.82 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £465.61 |
APC Smart-UPS SRT 3000VA RM Network Card | In Stock | £3,135.21 |
APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ | In Stock | £1,916.08 |
APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V | In Stock | £2,236.25 |
APC Smart-UPS 750VA RM 230V SmartConnect | In Stock | £524.45 |
