APC NetShelter SX 42U 600mm x 1070mm Deep Enclosure
Quicklinx: 4TPHWS00 Mfr#: AR3100
Depth (mm): 107cm
Type: Floor standing
U Height: 42U
Width (mm): 60cm
Hurry, only 3 left in stock!
£1,351.64 ex VAT
£1,621.96 inc VAT
The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
APC NetShelter SX Enclosure with Sides - rack - 42U
Rack
Rack Size
19"
Height (Rack Units)
42U
60 cm x 107 cm x 199 cm
125 kg
Wheels, keyed alike, adjustable depth
5-year warranty
Rack
Rack Size
19"
Height (Rack Units)
42U
60 cm
107 cm
199 cm
125 kg
Weight Limit
1364 kg
Mounting Kit
Included
EIA-310-D, UL 60950, IEC 60529 IP20, RoHS, BAA
TAA Compliant
Limited warranty: parts and labour - 5 years
4TPH APC Basic Rack-Mount PDU - power distribution strip In Stock £203.09
4TPH APC 1U Vertical Cable Organiser In Stock £121.12
4TPH APC 1U Horizontal Cable Organiser In Stock £52.33
4TPH APC Smart-UPS SC 450VA 1U In Stock £277.12
4TPH APC - rack cable guide - 1U In Stock £50.67
4TPH APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £203.79
4TPH APC Rack PDU Basic Zero U 16A 208/230V In Stock £293.40
4TPH APC Smart-UPS 5000VA In Stock £3,629.00
4TPH APC Rack PDU Basic Zero U 32A 230V In Stock £312.30
4TPH APC Smart-UPS RT 20kVA RM 230V In Stock £12,076.87
4TPH APC Equipment Support Rails for 600mm Wide Enclosure In Stock £72.21
4TPH APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £285.33
4TPH APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,111.55
4TPH APC Cable Managers (Qty 10) In Stock £34.52
4TPH APC 2G Power distribution strip In Stock £639.87
4TPH APC Rack PDU 2G METERED ZEROU In Stock £673.83
4TPH APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,280.31
4TPH APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,645.88
4TPH APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £962.06
4TPH APC 19" Rack LCD Console In Stock £1,374.58
4TPH APC Fixed Shelf - 50lbs/23kg, Black In Stock £80.55
4TPH APC NetShelter Zero U Accessory Mounting Bracket In Stock £65.74
4TPH APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,446.46
4TPH APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,901.11
4TPH APC 1U Blanking Panel Kit In Stock £33.92
4TPH APC Smart-UPS SRT UPS 5000 Watt Lead Acid In Stock £4,154.60
4TPH APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £55.68
4TPH APC Smart-UPS SRT 6000VA RM 230V In Stock £4,845.67
4TPH APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £47.66
4TPH APC Smart-UPS SRT 8000VA RM 230V In Stock £6,048.40
4TPH APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £68.75
4TPH APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,371.49
4TPH APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,631.63
4TPH APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £630.87
4TPH APC Smart-UPS SRT 2200VA RM 230V In Stock £1,760.91
4TPH APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,755.37
4TPH APC Metered Rack PDU In Stock £838.72
4TPH APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,174.64
4TPH APC Switched Rack PDU AC 208-230 V Ethernet In Stock £740.02
4TPH APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.82
4TPH APC Smart-UPS SRT 10000VA RM 230V In Stock £7,056.93
4TPH APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £597.13
4TPH APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £713.02
4TPH APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £886.64
4TPH APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,248.14
4TPH APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £160.46
4TPH APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.43
4TPH APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,514.94
4TPH APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £465.61
4TPH APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,195.44
4TPH APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,908.20
4TPH APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,236.33
4TPH APC Smart-UPS 750VA RM 230V SmartConnect In Stock £524.45
Resources
The following resources are available for the APC NetShelter SX 42U 600mm x 1070mm Deep Enclosure
Depth (mm): 107cm
U Height: 42U
Width (mm): 60cm
Brand: APC
Price Range Ex VAT: £1000 - £1500
