The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
- APC NetShelter SX Enclosure with Sides - rack - 42U
- Product Type
- Rack
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 42U
- 60 cm x 107 cm x 199 cm
- 125 kg
- Wheels, keyed alike, adjustable depth
- 5-year warranty
- Product Type
- Rack
- Rack Size
- 19"
- 42U
- 60 cm
- 107 cm
- 199 cm
- 125 kg
- Black
- Weight Limit
- 1364 kg
- Mounting Kit
- Included
- EIA-310-D, UL 60950, IEC 60529 IP20, RoHS, BAA
- TAA Compliant
- Limited warranty: parts and labour - 5 years
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £202.03 |
APC 1U Vertical Cable Organiser | In Stock | £122.75 |
APC 1U Horizontal Cable Organiser | In Stock | £54.86 |
APC Smart-UPS SC 450VA 1U | In Stock | £283.64 |
APC Netshelter heavy duty shelf | In Stock | £142.89 |
APC - rack cable guide - 1U | In Stock | £51.09 |
APC Rackmount Rail Kit | In Stock | £92.13 |
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £206.47 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £299.80 |
APC Smart-UPS 5000VA | In Stock | £3,719.28 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £320.46 |
APC Smart-UPS RT 20kVA RM 230V | In Stock | £12,203.57 |
APC Equipment Support Rails for 600mm Wide Enclosure | In Stock | £73.19 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £287.81 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,193.02 |
