This 12 U vertical mounting rail kit bolts into pre-existing holes in the Netshelter CX mini to convert the basic enclosure into a 12 U rack enclosure with a fixed rack depth of 600 mm (26").
Quick install vertical mounting rail kit
Using pre-existing holes and supplied hardware, these vertical mounting rails fit quickly and conveniently into place, transforming the CX Mini into a 12U Rack Enclosure
- APC NetShelter CX Mini 12U Vertical Mounting Rail Kit - rack rail kit - 12U
- Product Type
- Rack rail kit
- Black
- Height (Rack Units)
- 12U
- 12 cm x 5.6 cm x 53.6 cm
- 1.1 kg
- 2-year warranty
- Designed For
- P/N: AR4000MV, AR4000MVX429, AR4000MVX432, NBWL0355A, SMC15002U-BR, SMX3000HV-BR
- Product Type
- Rack rail kit
- 12U
- 12 cm
- 5.6 cm
- 53.6 cm
- 1.1 kg
- Black
- RoHS, REACH
- TAA Compliant
- Limited warranty: - 2 years
- Designed For
