Acoustic foam lining for noise dampening
Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment. -
Adjustable equipment mounting rails
The equipment mounting rails, front and rear, are fully adjustable for various mounting depths, for rear-facing equipment mounting or additional clearance from the front door. Maximum rack depth 88 cm/34.6 in. Minimum rack depth 12 cm/4.7 in. -
Dedicated rear cable access point
The cable port has a capacity of up to 400 cables and is situated perfectly for ground or under-floor cabling. -
Four vertical 0U accessory channels and cable containment brackets
Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space. -
Integrated heat removal
High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment. -
Integrated power distribution
Provided with a rack power distribution unit servers and other equipment are ready for deployment. -
Light oak veneer finish
The enclosure blends discretely into almost any office environment. -
Removable side panels
Provides customers with easy accessibility to equipment.
- APC NetShelter CX - rack - 38U
- Product Type
- Rack
- Light oak
- Rack Size
- 19"
- Height (Rack Units)
- 38U
- 75 cm x 113 cm x 199.5 cm
- 200 kg
- Key lock, vertical cable management, casters, veneer case cover
- 2-year warranty
- Product Type
- Rack
- Rack Size
- 19"
- 38U
- 75 cm
- 113 cm
- 199.5 cm
- 200 kg
- Light oak
- Weight Limit
- 250 kg
- Plug and Play, RoHS
- Limited warranty: - 2 years
- Sound Emission
- 18.9 dB
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £205.36 |
APC 1U Horizontal Cable Organiser | In Stock | £56.26 |
APC Smart-UPS SC 450VA 1U | In Stock | £282.96 |
APC Netshelter heavy duty shelf | In Stock | £143.52 |
APC Rackmount Rail Kit | In Stock | £91.78 |
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £207.04 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £303.12 |
APC Smart-UPS 5000VA | In Stock | £3,723.51 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £300.02 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,205.29 |
APC Cable Managers (Qty 10) | In Stock | £36.89 |
APC 2G Power distribution strip | In Stock | £648.30 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V | In Stock | £2,355.52 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card | In Stock | £2,698.55 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £973.78 |
APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U | In Stock | £1,480.96 |
APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA | In Stock | £1,959.69 |
APC 1U Blanking Panel Kit | In Stock | £35.27 |
APC Smart-UPS SRT UPS 5000 Watt Lead Acid | In Stock | £4,210.13 |
APC Smart-UPS 1500VA LCD RM 1U 230V | In Stock | £975.29 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.59 |
APC Smart-UPS SRT 6000VA RM 230V | In Stock | £4,871.63 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £49.57 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.10 |
APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V | In Stock | £2,417.66 |
APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net | In Stock | £1,655.30 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £647.80 |
APC Smart-UPS SRT 2200VA RM 230V | In Stock | £1,810.91 |
APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid | In Stock | £2,823.33 |
APC Metered Rack PDU | In Stock | £880.85 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,202.64 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £773.47 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,113.73 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £63.47 |
APC Smart-UPS SRT 5000VA RM 208/230V HW | In Stock | £4,567.56 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £682.35 |
APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) | In Stock | £608.84 |
APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) | In Stock | £721.06 |
APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) | In Stock | £905.26 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £163.71 |
APC Smart UPS 2200VA LCD RM 2U 230 | In Stock | £1,536.52 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £466.12 |
APC Smart-UPS SRT 3000VA RM Network Card | In Stock | £3,211.80 |
APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ | In Stock | £1,963.45 |
APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V | In Stock | £2,291.61 |
APC Smart-UPS 750VA RM 230V SmartConnect | In Stock | £530.48 |
APC Smart-UPS 750VA LCD 230V | In Stock | £360.60 |
