APC NetShelter CX 38U Secure Soundproofed Server Room in Box Enc
Quicklinx: FK7QWS00 Mfr#: AR4038IA
£5,411.21 ex VAT
£6,493.45 inc VAT
NetShelter CX 38U Secure Soundproof Server Room in a Box Enclosure International.
  • Acoustic foam lining for noise dampening
    Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment.
  • Adjustable equipment mounting rails
    The equipment mounting rails, front and rear, are fully adjustable for various mounting depths, for rear-facing equipment mounting or additional clearance from the front door. Maximum rack depth 88 cm/34.6 in. Minimum rack depth 12 cm/4.7 in.
  • Dedicated rear cable access point
    The cable port has a capacity of up to 400 cables and is situated perfectly for ground or under-floor cabling.
  • Four vertical 0U accessory channels and cable containment brackets
    Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space.
  • Integrated heat removal
    High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment.
  • Integrated power distribution
    Provided with a rack power distribution unit servers and other equipment are ready for deployment.
  • Light oak veneer finish
    The enclosure blends discretely into almost any office environment.
  • Removable side panels
    Provides customers with easy accessibility to equipment.
APC NetShelter CX - rack - 38U
Rack
Light oak
Rack Size
19"
Height (Rack Units)
38U
75 cm x 113 cm x 199.5 cm
200 kg
Key lock, vertical cable management, casters, veneer case cover
Rack
Rack Size
19"
Height (Rack Units)
38U
75 cm
113 cm
199.5 cm
200 kg
Light oak
Weight Limit
250 kg
Plug and Play, RoHS
Limited warranty: - 2 years
Sound Emission
18.9 dB
FK7Q APC Basic Rack-Mount PDU - power distribution strip In Stock £202.03
FK7Q APC 1U Vertical Cable Organiser In Stock £122.75
FK7Q APC 1U Horizontal Cable Organiser In Stock £54.86
FK7Q APC Smart-UPS SC 450VA 1U In Stock £282.48
FK7Q APC Netshelter heavy duty shelf In Stock £142.40
FK7Q APC - rack cable guide - 1U In Stock £51.02
FK7Q APC Rackmount Rail Kit In Stock £92.13
FK7Q APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £206.47
FK7Q APC Rack PDU Basic Zero U 16A 208/230V In Stock £296.33
FK7Q APC Smart-UPS 5000VA In Stock £3,710.63
FK7Q APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £286.82
FK7Q APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,191.92
FK7Q APC Cable Managers (Qty 10) In Stock £35.34
FK7Q APC 2G Power distribution strip In Stock £645.98
FK7Q APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,353.94
FK7Q APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,681.70
FK7Q APC 19" Rack LCD Console In Stock £1,380.49
FK7Q APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.00
FK7Q APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,480.64
FK7Q APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,926.85
FK7Q APC 1U Blanking Panel Kit In Stock £34.72
FK7Q APC Smart-UPS SRT UPS 5000 Watt Lead Acid In Stock £4,203.65
FK7Q APC Smart-UPS 1500VA LCD RM 1U 230V In Stock £971.08
FK7Q APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.96
FK7Q APC Smart-UPS SRT 6000VA RM 230V In Stock £4,842.94
FK7Q APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.30
FK7Q APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.94
FK7Q APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,403.60
FK7Q APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,654.55
FK7Q APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £636.90
FK7Q APC Smart-UPS SRT 2200VA RM 230V In Stock £1,802.70
FK7Q APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,819.85
FK7Q APC Metered Rack PDU In Stock £843.83
FK7Q APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,202.40
FK7Q APC Switched Rack PDU AC 208-230 V Ethernet In Stock £736.14
FK7Q APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.62
FK7Q APC Switched PDU 10A 0U C13x16 In Stock £1,159.72
FK7Q APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £659.31
FK7Q APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £606.31
FK7Q APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £722.53
FK7Q APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £904.51
FK7Q APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £161.21
FK7Q APC Rack PDU Basic 0U/1U 100-240V/ In Stock £81.93
FK7Q APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,535.30
FK7Q APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £468.57
FK7Q APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,195.64
FK7Q APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,901.46
FK7Q APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,289.38
FK7Q APC Smart-UPS 750VA RM 230V SmartConnect In Stock £531.44
FK7Q APC Smart-UPS 750VA LCD 230V In Stock £358.20
Brand: APC
Price Range Ex VAT: £1500+
