Specialized enclosures with integrated cooling, noise dampening, and power distribution for server and network applications in office environments.
Integrated heat removal
High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment -
Integrated power distribution
Provided with a rack power distribution unit servers and other equipment are ready for deployment -
Light oak veneer finish
The enclosure blends discretely into almost any office environment -
Six vertical 0U accessory channels
Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space -
Dedicated rear cable access point
The cable port has a capacity of up to 400 cables and is situated perfectly for ground or under-floor cabling -
Acoustic foam lining for noise dampening
Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment -
Adjustable equipment mounting rails
The equipment mounting rails, front and rear, are fully adjustable for various mounting depths, for rear-facing equipment mounting or additional clearance from the front door. Maximum rack depth 88 cm/34.6 in. Minimum rack depth 12 cm/4.7 in -
Removable side panels
Provides customers with easy accessibility to equipment
- APC NetShelter CX - rack - 18U
- Product Type
- Rack
- Built-in Devices
- Power distribution unit
- Light oak
- Rack Size
- 19"
- Height (Rack Units)
- 18U
- 75 cm x 113 cm x 101.5 cm
- 138 kg
- Wheels, key lock
- 2-year warranty
- Product Type
- Rack
- Built-in Devices
- Rack Size
- 19"
- 18U
- 75 cm
- 113 cm
- 101.5 cm
- 138 kg
- Light oak
- Weight Limit
- 310 kg
- Wheels, key lock
- Plug and Play, RoHS
- Limited warranty: - 2 years
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £204.64 |
APC 1U Horizontal Cable Organiser | In Stock | £55.47 |
APC Smart-UPS SC 450VA 1U | In Stock | £279.98 |
APC Netshelter heavy duty shelf | In Stock | £141.95 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £302.47 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £289.09 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,186.69 |
APC Cable Managers (Qty 10) | In Stock | £36.38 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V | In Stock | £2,317.04 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 | In Stock | £511.74 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card | In Stock | £2,667.34 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £80.88 |
APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U | In Stock | £1,457.00 |
APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA | In Stock | £1,908.54 |
APC 1U Blanking Panel Kit | In Stock | £34.80 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £55.94 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.98 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £69.11 |
APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V | In Stock | £2,389.72 |
APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net | In Stock | £1,639.84 |
APC Smart-UPS SRT 2200VA RM 230V | In Stock | £1,801.52 |
APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid | In Stock | £2,782.64 |
APC Metered Rack PDU | In Stock | £856.35 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,185.53 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,097.93 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £62.16 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £677.83 |
APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) | In Stock | £595.90 |
APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) | In Stock | £717.17 |
APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) | In Stock | £891.35 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £163.11 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £84.13 |
APC Smart UPS 2200VA LCD RM 2U 230 | In Stock | £1,488.58 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £472.34 |
APC Smart-UPS SRT 3000VA RM Network Card | In Stock | £3,171.15 |
APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ | In Stock | £1,932.30 |
APC Smart-UPS 750VA RM 230V SmartConnect | In Stock | £525.39 |
APC Smart-UPS 750VA LCD 230V | In Stock | £353.80 |
