APC NetShelter CX 18U 750 mm Wide x 1130 mm Deep Enclosure
Quicklinx: CP5YWS00 Mfr#: AR4018IX429
This product is a specialized enclosure with integrated cooling, noise dampening, and power distribution for server and network applications in office environments.
  • Integrated heat removal
    High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment
  • Integrated power distribution
    Provided with a rack power distribution unit servers and other equipment are ready for deployment
  • Six vertical 0U accessory channels
    Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space
  • Dedicated rear cable access point
    The cable port has a capacity of up to 400 cables and is situated perfectly for ground or under-floor cabling
  • Acoustic foam lining for noise dampening
    Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment
  • Adjustable equipment mounting rails
    The equipment mounting rails, front and rear, are fully adjustable for various mounting depths, for rear-facing equipment mounting or additional clearance from the front door. Maximum rack depth 88 cm/34.6 in. Minimum rack depth 12 cm/4.7 in
  • Removable side panels
    Provides customers with easy accessibility to equipment
  • Compatibility with enhanced enclosure access security options
    Enclosure is provided standard with front, rear, side locking components and is designed for compatibility with increased security options such as combination-style and electronic swipe access handles
APC NetShelter CX - rack - 18U
Rack
Package Content
Side panels, keys, PDU (Power Distribution Unit), levelling feet, casters
Rack Size
19"
Height (Rack Units)
18U
75 cm x 113 cm x 101.5 cm
131 kg
Noise reduction, lockable, built-in cooling fan
Rack
Package Content
Rack Size
19"
Height (Rack Units)
18U
75 cm
113 cm
101.5 cm
131 kg
Weight Limit
830 kg
Limited warranty: - 2 years
