APC NetBotz Rack Sensor Pod 150
Quicklinx: DJL5WS00 Mfr#: NBPD0150
£178.27 ex VAT
£213.92 inc VAT
The Rack Sensor Pod 150 includes six universal sensor ports for monitoring input from APC environmental sensors and other third-party sensors.
  • 24 VDC input
    Provides supplemental power for high-current load configurations. Supplemental power is not required for most system configurations.
  • Link ports
    Standard CAT-5 cabling with straight-through wiring is required. Depending on the rack or room monitor to which the Rack Sensor Pod 150 is connected, multiple devices may be cascaded along an A-Link bus.
  • Identifier # LED display
    Displays a unique identifier number. The first time a Rack Sensor Pod 150 receives power, it obtains a unique Identifier #. When the Rack Sensor Pod 150 is connected to certain NetBotz products, the Identifier # LED will blink when an alert occurs for the Rack Sensor Pod 150.
  • Universal sensor ports
    Used for connecting APC sensors, third-party dry contact sensors, and standard third-party 0-5 V sensors.
NetBotz Rack Sensor Pod 150 - rack sensor pod
Rack sensor pod
33.7 cm x 4.3 cm x 4.3 cm
Rack sensor pod
33.7 cm
4.3 cm
4.3 cm
GOST, ICES-003, NOM, VCCI Class A ITE, FCC Part 15 A, C-Tick Class A
45 °C
Brand: APC
