APC NETBOTZ RACK MONITOR 450
Quicklinx: 7B11WS00 Mfr#: NBRK0450
The NetBotz 450 offers high performance security and environmental monitoring over the network. The NetBotz 450 is capable of video surveillance and monitoring to record human activity. It provides temperature, humidity, door contact, dry contact, 0-5V, 4-20mA, spot leak, vibration, smoke, 2 way audio, and alarm beacon monitoring. The NetBotz 450's additional features include integration with InfraStruXure central, power over Ethernet, and userdefined alerts making the NetBotz 450 the perfect unit to protect your IT assets from security and environmental threats. The NetBotz 450 can be used in network closets to data centers, but it is commonly installed in server rooms and small data centers.
  • Access monitoring
    Detect access by unauthorized personnel via door switch.
  • Environmental monitoring
    Prevent equipment failure from a full range of threatening environmental conditions.
  • Surveillance
    Detect and record motion, allowing a visual record to be paired with an access or environmental alert, which speeds root cause analysis.
  • Fault notification
    Real-time event notification minimizes response times to critical physical infrastructure situations. Enables IT administrators to reduce mean time to repair, improve efficiency, and maximize uptime.
  • Adjustable threshold
    Customize threshold definitions (multiple thresholds per sensor, scheduling, severity levels) to your requirements.
  • Customized escalation policies
    Alerts are managed according to your escalation policies and received in multiple formats.
  • Browser accessible
    View the user interface with a browser. Provides quick access from anywhere on a secure network.
  • Event-driven video storage
    Video storage prompted by motion or alert.
  • Integrates with InfraStruXure central
    An IT-ready, scalable monitoring system that collects, organizes, and distributes critical alerts, surveillance video and key information, providing a unified view of complex physical infrastructure environments from anywhere on the network.
  • Advanced view client application
    Robust appliance interface provides historic alerts, graphs, and configuration.
  • Enterprise management system compatible
    Manage your APC devices from a single system by forwarding SNMP traps (events) to your preferred enterprise management system.
  • Alerts view
    Easily review and correlate alerts. Provide context to alerts by attaching video clips, graphs, and maps.
NetBotz 450 - environment monitoring device
Environment monitoring device
Rack-mountable - 1U
Ethernet, Fast Ethernet
Temperature & humidity sensor
43.2 cm x 9.3 cm x 4.4 cm
1.7 kg
Height (Rack Units)
1U
43.2 cm
9.3 cm
4.4 cm
1.7 kg
Rack-mountable
Wired
Network / Transport Protocol
TCP/IP, SMTP, DHCP, DNS
Remote Management Protocol
SNMP, HTTP
Status Indicators
Power, alert, temperature, sound detected, humidity out-of-limit, status, airflow out-of-limit, equipment condition detected, link/activity
DHCP support
1 x 100Base-TX - RJ-45 , 1 x USB - Type B , 2 x USB - Type A
1 x USB cable
FCC Class A certified, UL, VCCI
Limited warranty - parts and labour - 2 years
45 °C
10 - 95%
