The NetBotz 450 offers high performance security and environmental monitoring over the network. The NetBotz 450 is capable of video surveillance and monitoring to record human activity. It provides temperature, humidity, door contact, dry contact, 0-5V, 4-20mA, spot leak, vibration, smoke, 2 way audio, and alarm beacon monitoring. The NetBotz 450's additional features include integration with InfraStruXure central, power over Ethernet, and userdefined alerts making the NetBotz 450 the perfect unit to protect your IT assets from security and environmental threats. The NetBotz 450 can be used in network closets to data centers, but it is commonly installed in server rooms and small data centers.
Access monitoring
Detect access by unauthorized personnel via door switch. -
Environmental monitoring
Prevent equipment failure from a full range of threatening environmental conditions. -
Surveillance
Detect and record motion, allowing a visual record to be paired with an access or environmental alert, which speeds root cause analysis. -
Fault notification
Real-time event notification minimizes response times to critical physical infrastructure situations. Enables IT administrators to reduce mean time to repair, improve efficiency, and maximize uptime. -
Adjustable threshold
Customize threshold definitions (multiple thresholds per sensor, scheduling, severity levels) to your requirements. -
Customized escalation policies
Alerts are managed according to your escalation policies and received in multiple formats. -
Browser accessible
View the user interface with a browser. Provides quick access from anywhere on a secure network. -
Event-driven video storage
Video storage prompted by motion or alert. -
Integrates with InfraStruXure central
An IT-ready, scalable monitoring system that collects, organizes, and distributes critical alerts, surveillance video and key information, providing a unified view of complex physical infrastructure environments from anywhere on the network. -
Advanced view client application
Robust appliance interface provides historic alerts, graphs, and configuration. -
Enterprise management system compatible
Manage your APC devices from a single system by forwarding SNMP traps (events) to your preferred enterprise management system. -
Alerts view
Easily review and correlate alerts. Provide context to alerts by attaching video clips, graphs, and maps.
- NetBotz 450 - environment monitoring device
- Environment monitoring device
- Form Factor
- Rack-mountable - 1U
- Data Link Protocol
- Ethernet, Fast Ethernet
- Included Accessories
- Temperature & humidity sensor
- 43.2 cm x 9.3 cm x 4.4 cm
- 1.7 kg
- 2-year warranty
- Height (Rack Units)
- 1U
- 43.2 cm
- 9.3 cm
- 4.4 cm
- 1.7 kg
- Form Factor
- Rack-mountable
- Connectivity Technology
- Wired
- TCP/IP, SMTP, DHCP, DNS
- Remote Management Protocol
- SNMP, HTTP
- Status Indicators
- Power, alert, temperature, sound detected, humidity out-of-limit, status, airflow out-of-limit, equipment condition detected, link/activity
- DHCP support
- 1 x 100Base-TX - RJ-45 , 1 x USB - Type B , 2 x USB - Type A
- Cables Included
- 1 x USB cable
- FCC Class A certified, UL, VCCI
- Limited warranty - parts and labour - 2 years
- 0 °C
- 45 °C
- 10 - 95%
