If you're managing multiple servers, particularly in a mixed OS environment, UPS Interface Expander is essential tool to properly manage signaling servers from your SmartUPS, MatrixUPS, Symmetra Power Array, or Silcon UPS.
- APC Interface Expander - remote management adapter - SmartSlot - 2 ports
- Remote management adapter
- Form Factor
- Plug-in module
- Interface (Bus) Type
- SmartSlot
- 12.1 cm x 10.8 cm x 3.8 cm
- 0.1 kg
- Ports Qty
- 2 ports
- 2-year warranty
- Designed For
- P/N: AIS5000-IS10KG, AIS5000-IS20KG, AIS5000-IS40KG, IS100KG, IS10KG, IS20KG, IS30KG, IS40KG, IS60KG, IS80KG, SU3000RMNET-1EW, SU5000R5XLT-TF3-TU, SUA2200RMXLI3U, SUA5000RMI5U, SUA750IX38, SUM3000RMXL2U, SUM3000RMXL2U-TU, SURT3000XLI/S, SURT3000XLT-1TF3TR, SURTA3000XL, SURTA3000XL-TU
- Remote management adapter - 2 ports
- Form Factor
- Plug-in module
- SmartSlot
- Connectivity Technology
- Wired
- 2 x management
- Compatible Slots
- 1 x SmartSlot
- Cables Included
- 2 (external)
- FCC Class B certified, C-Tick, EN55024
- 12.1 cm
- 10.8 cm
- 3.8 cm
- 0.1 kg
- Limited warranty - 2 years
- 0 °C
- 35 °C
- 0 - 95%
- Max Altitude Operating
- 3 km
- Designed For
- P/N: AIS5000-IS10KG, AIS5000-IS20KG, AIS5000-IS40KG, IS100KG, IS10KG, IS20KG, IS30KG, IS40KG, IS60KG, IS80KG, SU1000RMI, SU1400RMXLB3U, SU1400RMXLB3U-TRAD, SU1400RMXLB3U-TU, SU1400RMXLI3U U, SU1400RMXLI3U-1EW, SU1400RMXLI3U-2EW, SU1400RMXLI3U-3EW, SU1400RMXLIB3U, SU2200R3X152-TU, SU2200RM, SU2200RMI3U.1, SU2200RMNET, SU2200RMXL, SU2200RMXL3U-TU, SU2200RMXLI3U-1EW, SU2200RMXLI3U-2EW, SU2200RMXLI3U-3EW, SU2200RMXLINET-1EW, SU2200RMXLINET-2EW, SU2200RMXLINET-3EW, SU3000R3IBX135, SU3000R3IX160, SU3000R3X145-TU, SU3000RMINET-1EW, SU3000RMINET-2EW, SU3000RMINET-3EW, SU3000RMNET-1EW, SU3000RMXLI3U-1EW, SU3000RMXLI3U-2EW, SU3000RMXLI3U-3EW, SU5000R51BX120, SU5000R5TBX120-TU, SU5000R5TBXFMR, SU5000R5TBXFMR-TU, SU5000R5T-TF3, SU5000R5T-TF3-TU, SU5000R5XLT-TF3, SU5000R5XLT-TF3-TU, SU5000R5XLTXFMR, SU5000R5XLTXFMR-TU, SU5000RMI5U-1EW, SU5000RMI5U-2EW, SU5000RMI5U-3EW, SU5000RMT5U-TU, SU5000RMXLI5U, SU5000RMXLI5U-1EW, SU5000RMXLI5U-2EW, SU5000RMXLI5U-3EW, SU5000RMXLT5U, SU700R2BX120-TU, SU700RM, SU700RMI2U-1EW, SU700RMI2U-2EW, SU700RMI2U-3EW, SUA1000RM2U, SUA1000RM2U-TU, SUA1000RMI2U, SUA1000RMI2U-3EW, SUA1000RMI2U-GLD, SUA1000RMUS, SUA1500RMI2U, SUA1500RMI2U-2EW, SUA1500RMI2U-SLV, SUA1500RMUS, SUA2200RMI2U-1EW, SUA2200RMI2U-SLV, SUA2200RMXLI3U, SUA3000, SUA3000I, SUA3000R2IX322, SUA3000R2X145, SUA3000R2X145-TU, SUA3000RM2U, SUA3000RM2U-TU, SUA3000RMI, SUA3000RMI2U, SUA3000RMI2U-1EW, SUA3000RMI2U-2EW, SUA3000RMI2U-3EW, SUA3000RMI2U-BRZ, SUA3000RMI2U-GLD, SUA3000RMI2U-SLV, SUA3000RMT2U, SUA3000RMUS, SUA3000RT2X136, SUA5000RMI5U, SUA750IX38, SUA750RM1U, SUA750RM2U, SUA750RM2U-TU, SUA750RMI1U, SUA750RMI2U, SUA750RMI2U-3EW, SUA750RMI2U-BRZ, SUA750RMI2U-GLD, SUA750RMI2U-SLV, SUA750RMJ1UB, SUM3000RMXL2U, SUM3000RMXL2U-TU, SURT3000XLI, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU, SURT3000XLT, SURT3000XLT-1TF3, SURT3000XLT-1TF3TR, SURT3000XLT-TU, SURT7500RMXLT-1TF5, SURTA3000XL, SURTA3000XL-TU
