APC's SurgeArrest was designed in response to customer requests for additional safety and convenience features. APC introduced plug-activated safety shutter and cord management to deliver increased security and ease of use, while superior power line and data line surge protection prevents damaging surge and spikes from ever reaching your equipment.
Resettable circuit breaker
Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs) -
Manual disconnect switch
Enables the surge supressor to be de-energized for service without disconnecting the protected load -
Right Angle Plug
Plug angle allows for equipment and furniture to be placed closer to the wall than with a standard power cord. Reduces cord stress too
- APC SurgeArrest Home/Office - surge protector
- Surge protector - external
- 1.1 kg
- Localisation
- United Kingdom
- Input Connectors
- 1 x power BS 1363
- Output connectors
- 6 x power BS 1363
- Charcoal
- 12.2 cm x 4.2 cm x 30.5 cm
- Limited lifetime warranty
- Charcoal
- Localisation
- United Kingdom
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power BS 1363
- Power Output Connectors Details
- 6 x power BS 1363
- Max Electric Current
- 13 A
- Dataline Surge Protection
- Phone line - RJ-11 - 1 input line / 2 output lines , Cable TV - RCA
- Surge Suppression
- Surge Energy Rating
- 2030 Joules
- EMI/RFI Noise Filtration
- 50 dB
- Circuit Protection
- Circuit breaker
- Cables Included
- Power cable - integrated - 2.4 m , 2 x phone cable - external - 1.8 m , Coaxial RF cable - external - 1.8 m
- GOST, UL 1449
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 95%
- 12.2 cm
- 4.2 cm
- 30.5 cm
- 1.1 kg
