APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
- APC Symmetra Power Module - UPS - 2.8 kW - 4000 VA
- UPS - plug-in module
- Rack Size
- 4U
- 15 kg
- Input Voltage
- AC 230/400 V
- Output Voltage
- AC 230 V
- Power Capacity
- 2.8 kW / 4000 VA
- Output connectors
- 1 x hardwire 3-wire (HN + E)
- 25 cm x 56 cm x 15 cm
- 2-year warranty
- Designed For
- P/N: SYA12K16ICH, SYA12K16IXRCH, SYA12K16RMI-3HAVL, SYA12K16RMICH, SYA16K16ICH, SYA16K16IXRCH, SYA16K16RMI-3HAVL, SYA16K16RMI-5HAVL, SYA16K16RMICH, SYA4K8RMI-3HAVL, SYA4K8RMI-5HAVL, SYA8K16ICH, SYA8K16RMI/2, SYA8K16RMICH, SYA8K8I-3HAVL, SYA8K8I-5HAVL, SYA8K8RMI-3HAVL, SYA8K8RMI-5HAVL
- Height (Rack Units)
- 4U
- Input Voltage
- AC 230/400 V
- Input Voltage Range
- AC 155/276 - 290/480 V
- Frequency Required
- 45 - 65 Hz
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Power Capacity
- 2.8 kW / 4000 VA
- C-Tick, EN 60950, VDE, IEC 60950, EN55024, EN55022 Class A, EN 50091-2
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 25 cm
- 56 cm
- 15 cm
- 15 kg
- Designed For
- P/N: SYA12K16I, SYA12K16I-3AVL, SYA12K16I-3HAVL, SYA12K16I-3XW, SYA12K16I-5AVL, SYA12K16I-5HAVL, SYA12K16I-5XW, SYA12K16ICH, SYA12K16I-TU, SYA12K16IXR, SYA12K16IXR-3AVL, SYA12K16IXR-3HAVL, SYA12K16IXR-3XW, SYA12K16IXR-5AVL, SYA12K16IXR-5HAVL, SYA12K16IXR-5XW, SYA12K16IXRCH, SYA12K16RMI, SYA12K16RMI-3AVL, SYA12K16RMI-3HAVL, SYA12K16RMI-3XW, SYA12K16RMI-5AVL, SYA12K16RMI-5HAVL, SYA12K16RMI-5XW, SYA12K16RMICH, SYA16K16I, SYA16K16I-3AVL, SYA16K16I-3HAVL, SYA16K16I-3XW, SYA16K16I-5AVL, SYA16K16I-5HAVL, SYA16K16I-5XW, SYA16K16ICH, SYA16K16IXR, SYA16K16IXR-3AVL, SYA16K16IXR-3HAVL, SYA16K16IXR-3XW, SYA16K16IXR-5AVL, SYA16K16IXR-5HAVL, SYA16K16IXR-5XW, SYA16K16IXRCH, SYA16K16RMI, SYA16K16RMI-3AVL, SYA16K16RMI-3HAVL, SYA16K16RMI-3XW, SYA16K16RMI-5AVL, SYA16K16RMI-5HAVL, SYA16K16RMI-5XW, SYA16K16RMICH, SYA4K8I, SYA4K8RMI, SYA4K8RMI-3AVL, SYA4K8RMI-3HAVL, SYA4K8RMI-3XW, SYA4K8RMI-5AVL, SYA4K8RMI-5HAVL, SYA4K8RMI-5XW, SYA8K16I, SYA8K16ICH, SYA8K16IXR, SYA8K16RMI, SYA8K16RMI/2, SYA8K16RMI-3AVL, SYA8K16RMI-3HAVL, SYA8K16RMI-3XW, SYA8K16RMI-5AVL, SYA8K16RMI-5HAVL, SYA8K16RMI-5XW, SYA8K16RMICH, SYA8K8I, SYA8K8I-3AVL, SYA8K8I-3HAVL, SYA8K8I-3XW, SYA8K8I-5AVL, SYA8K8I-5HAVL, SYA8K8I-5XW, SYA8K8I-TU, SYA8K8RMI, SYA8K8RMI-3AVL, SYA8K8RMI-3HAVL, SYA8K8RMI-3XW, SYA8K8RMI-5AVL, SYA8K8RMI-5HAVL, SYA8K8RMI-5XW
