APC Fixed Shelf - 50lbs/23kg, Black
Quicklinx: 8KNTWS00 Mfr#: AR8105BLK
Product Type: Rack shelf, Rack shelf
Hurry, only 1 left in stock!
£66.16 ex VAT
£79.39 inc VAT
American Power Conversion (APC) is a global leader in the designing, manufacturing and marketing of power protection equipment, including surge suppressors, uninterruptible power supplies (UPS), power conditioning equipment and related software for computer and computer-related equipment. To keep its products well-supplied APC offers a wide range of accessories.
  • Ventilated
    Perforated front and rear doors provide ample ventilation for rack-mount equipment.
APC rack shelf - 2U
Rack shelf
Height (Rack Units)
2U
48.3 cm x 40.6 cm x 8.9 cm
2.3 kg
Vented
NetShelter 2 Post Open Frame Rack; NetShelter EP; NetShelter ES; NetShelter SX; Netshelter VX; NetShelter WX
Rack shelf
Height (Rack Units)
2U
48.3 cm
40.6 cm
8.9 cm
2.3 kg
Weight Limit
22.7 kg
Rack Mounting Kit
Included
Vented
EIA-310-D
APC NetShelter 2 Post Open Frame Rack , APC NetShelter EP , APC NetShelter ES , APC NetShelter SX , APC Netshelter VX , APC NetShelter WX
8KNT APC AP9520TH TEMP & HUMIDITY In Stock £216.78
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 8KNT 042542
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £10.04
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: APC
Stock Status: In stock
Stock Status: Used Stock
