APC Essential SurgeArrest 5 Outlet 230V
Quicklinx: F2XRWS00 Mfr#: PM5T-UK
Power Output Connectors: 5
£22.54 ex VAT
£27.04 inc VAT
The APC SurgeArrest Essential series represents the minimum level of surge protection that should be present on any of your computers and household electronics, with most models also providing surge protection for your phone lines. Its state of the art circuitry offers protection for sensitive electronic equipment against larger power surges and multiple surge events.
  • Protection Working Indicator
    SurgeArrest will warn you if its circuitry has been damaged by heavy strike or power line surge and it is unable to provide 100% protection. If still under warranty, APC will then replace your damaged SurgeArrest free of charge
  • IEEE let-through ratings and regulatory agency compliance
    APC surge protectors undergo stringent testing by IEEE, and are awarded "let-through ratings", which indicate the maximum voltage level that can possibly reach your equipment after a surge or voltage spike has passed through an electric surge protector. Lower IEEE let-through ratings indicate better protection and performance. The APC Essential SurgeArrest series offers optimal performance with a let-through rating of less than 330V to 500V for North American products, and a rating of less than 15% for products sold worldwide. All APC products comply with local agency safety requirements, including UL in North America and CE/Kema/Gost/C-tick/A-Tick/Telepermit in their respective regions
  • Data-line Protection
    Protection of data lines (Ethernet, Coaxial and Phone lines) ensures complete protection of your equipment from surges. It is very important to protect your equipment from “back door” electric surges traveling through data lines, as they can be as damaging to your equipment as surges traveling over power lines
  • EMI and RFI noise filtering
    Reduces line noise that can cause data loss and keyboard errors
APC SurgeArrest Essential - surge protector
Surge protector - external
690 g
United Kingdom
Input Voltage
AC 230 V
Input Connectors
1 x power BS 1363A
Output connectors
5 x power BS 1363
White
38.5 cm x 7.3 cm x 5.6 cm
White
United Kingdom
Input Voltage
AC 230 V
Frequency Required
50 Hz
Input Connectors
1 x power BS 1363A
5 x power BS 1363
Max Electric Current
13 A
Dataline Surge Protection
Phone line - RJ-11 - 1 input line / 1 output line
Surge Suppression
Surge Energy Rating
918 Joules
EMI/RFI Noise Filtration
40 dB
Max Spike Current
24000 A
Circuit Protection
Circuit breaker
Power cable - integrated - 1.83 m
Equipment Protection Value
50000 Euros
LED indicators
RoHS, REACH
Limited warranty - lifetime
0 - 90%
38.5 cm
7.3 cm
5.6 cm
690 g
Shipping Width
40.5 cm
Shipping Depth
13 cm
Shipping Height
5.8 cm
Shipping Weight
800 g
Brand: APC
