APC Easy UPS 3S 40 kVA 400 V 3:3 UPS for internal batteries
Quicklinx: GCRKWS00 Mfr#: E3SUPS40KHB
Power Rating: 40kW
£6,393.09 ex VAT
£7,671.70 inc VAT
High-efficiency 3-phase UPS that features advanced product features, competitive specifications, and robust electrical design, making business continuity easy in the data center or electrical room. This is an exceptionally easy to install, operate, maintain, and service 40 kVA UPS, ideal for small and medium businesses. Includes dust filter and conformance-coated boards for harsh environments. This UPS is for internal batteries, but is supplied without batteries, so you can easily customize the battery runtime. For battery runtime details, see the runtime charts published under the Documents tab.
  • Efficient power management
    The Schneider Electric Easy UPS 3S ensures efficient power management with a power capacity of 40,000 VA and 40 kW, providing stable power to your critical systems.
  • Wide input voltage range
    Designed to handle a wide input voltage range from AC 304 to 477 V, this UPS adapts to varying power conditions, ensuring uninterrupted service.
  • Robust environmental adaptability
    With an operating temperature range from 0°C to 40°C and humidity tolerance from 0 to 95% (non-condensing), the UPS is built to perform in diverse environments.
  • Comprehensive compliance
    Meets a broad spectrum of standards including IEC 62040-1-1, IEC 62040-2, and more, ensuring reliability and safety in its operations.
  • Quiet operation
    With a sound emission of only 60 dBA, this UPS operates quietly, minimizing noise in work environments.
Schneider Electric Easy UPS 3S E3SUPS40KHB - UPS - 40 kW - 40000 VA
UPS - external
158 kg
Input Wiring
3-phase
Input Voltage
AC 400 V
Output Voltage
AC 400 V ± 3%
Power Capacity
40 kW / 40000 VA
Dust filter
White
50 cm x 76 cm x 140 cm
1-year warranty
UPS - external
White
Input Voltage
AC 400 V
Input Voltage Range
AC 304 - 477 V
Frequency Provided
50/60 Hz
Input Wiring
3-phase
Frequency Required
45 - 65 Hz
Output Voltage
AC 400 V ± 3% - 50/60 Hz
Power Capacity
40 kW / 40000 VA
Dust filter
IEC 62040-3, IEC 62040-1-1, IEC 62040-2, WEEE, IP20, EAC, RCM, ISTA 2B, IEC 62040-4
Limited warranty - 1 year - on-site
0 - 95% (non-condensing)
Sound Emission
60 dBA
50 cm
76 cm
140 cm
158 kg
Shipping Width
68.3 cm
Shipping Depth
111.4 cm
Shipping Height
164 cm
Shipping Weight
195 kg
Power Rating: 40kW
Brand: APC
Price Range Ex VAT: £1500+
