APC Easy UPS 3S 30 kVA 400 V 3:1 UPS for internal batteries
Quicklinx: GCRJWS00 Mfr#: E3SUPS30K3IB
Power Rating: 30kW
£5,883.44 ex VAT
£7,060.12 inc VAT
High-efficiency 3-phase UPS that features advanced product features, competitive specifications, and robust electrical design, making business continuity easy in the data center or electrical room. This is an exceptionally easy to install, operate, maintain, and service 30 kVA UPS, ideal for small and medium businesses. Includes dust filter and conformance-coated boards for harsh environments. This UPS is for internal batteries, but is supplied without batteries, so you can easily customize the battery runtime. For battery runtime details, see the runtime charts published under the Documents tab.
  • Efficient Power Management
    With a power capacity of 30,000 VA and operating voltage of 400 V, this UPS effectively manages and distributes power to connected devices, ensuring stability and reliability.
  • Environmental Resilience
    Capable of operating in temperatures from 0°C to 40°C and humidity levels up to 95%, this UPS functions optimally in diverse physical environments.
  • User-Friendly Interface
    The integrated LCD display and LED indicators provide clear visibility of operational status, making it simple for users to monitor power conditions at a glance.
  • Robust Compliance Standards
    Compliant with standards such as IEC 62040 series and WEEE, this UPS ensures adherence to international safety and performance requirements.
  • Reliable Operation
    The UPS operates within an input voltage range of 304 - 477 V, providing consistent performance across a variety of electrical conditions.
Schneider Electric Easy UPS 3S E3SUPS30K3IB - UPS - 30 kW - 30000 VA
UPS - external
584 kg
Input Wiring
3-phase
Input Voltage
AC 400 V
Output Voltage
AC 400 V ± 3%
Power Capacity
30 kW / 30000 VA
No battery
Dust filter
White
50 cm x 96.9 cm x 140 cm
1-year warranty
UPS - external
White
Input Voltage
AC 400 V
Input Voltage Range
AC 304 - 477 V
Frequency Provided
50/60 Hz
Input Wiring
3-phase
Frequency Required
45 - 65 Hz
Output Voltage
AC 400 V ± 3% - 50/60 Hz
Power Capacity
30 kW / 30000 VA
Power Factor (PF)
0.99
No battery
Dust filter
LCD display, LED indicators
IEC 62040-3, IEC 62040-1-1, IEC 62040-2, WEEE, IP20, EAC, RCM, ISTA 2B, IEC 62040-4
Limited warranty - 1 year - on-site
0 - 95% (non-condensing)
Sound Emission
60 dBA
50 cm
96.9 cm
140 cm
584 kg
Shipping Width
68.3 cm
Shipping Depth
111.4 cm
Shipping Height
164 cm
Shipping Weight
638 kg
Power Rating: 30kW
Brand: APC
Price Range Ex VAT: £1500+
