APC Easy UPS 3S 20 kVA 400 V 3:1 UPS for internal batteries
Quicklinx: GCRHWS00 Mfr#: E3SUPS20K3IB
Power Rating: 20kW
£5,082.99 ex VAT
£6,099.58 inc VAT
High-efficiency 3-phase UPS that features advanced product features, competitive specifications, and robust electrical design, making business continuity easy in the data center or electrical room. This is an exceptionally easy to install, operate, maintain, and service 20 kVA UPS, ideal for small and medium businesses. Includes dust filter and conformance-coated boards for harsh environments. This UPS is for internal batteries, but is supplied without batteries, so you can easily customize the battery runtime. For battery runtime details, see the runtime charts published under the Documents tab.
  • Easy loop test
    Verifies UPS performance before you connect your load, without the need for a load bank.
  • Easy to install fast
    Quickly roll the compact and lightweight UPS into position.
  • Front-access servicing
    Simplifies installation and UPS maintenance while minimizing space requirements.
  • Intuitive user interface
    The intuitive graphical user interface allows for easy system configuration.
  • ECO mode
    Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection.
Schneider Electric Easy UPS 3S E3SUPS20K3IB - UPS - 20 kW - 20000 VA
UPS - external
122 kg
Input Wiring
3-phase
Input Voltage
AC 400 V
Output Voltage
AC 400 V ± 3%
Power Capacity
20 kW / 20000 VA
No battery
Dust filter
White
38 cm x 92.8 cm x 140 cm
1-year warranty
UPS - external
White
Input Voltage
AC 400 V
Input Voltage Range
AC 304 - 477 V
Frequency Provided
50/60 Hz
Input Wiring
3-phase
Frequency Required
45 - 65 Hz
Output Voltage
AC 400 V ± 3% - 50/60 Hz
Power Capacity
20 kW / 20000 VA
Power Factor (PF)
0.99
No battery
Dust filter
LCD display, LED indicators
IEC 62040-3, IEC 62040-1-1, IEC 62040-2, WEEE, IP20, EAC, RCM, ISTA 2B, IEC 62040-4
Limited warranty - 1 year - on-site
0 - 95% (non-condensing)
Sound Emission
60 dBA
38 cm
92.8 cm
140 cm
122 kg
Shipping Width
56.3 cm
Shipping Depth
101.4 cm
Shipping Height
164 cm
Shipping Weight
158 kg
Power Rating: 20kW
Brand: APC
Price Range Ex VAT: £1500+
