APC Easy UPS 3M 60kVA 400V 3:3 UPS for internal batteries
Quicklinx: GCRLWS00 Mfr#: E3MUPS60KHBS
Power Rating: 60kW
£9,142.63 ex VAT
£10,971.15 inc VAT
Easy-to-install, easy-to-connect, easy-to-use, and easy-to-service 60 kVA 3 phase UPS with advanced product features, robust electrical specifications and compact design making your business continuity easy. Ideal for small and medium data centers and other business critical applications, this UPS is EcoStruxure-ready to give you peace of mind with cloud-based remote monitoring and management. This UPS is for internal batteries, but is supplied without batteries, so you can easily customize the battery runtime. For battery runtime details, see the runtime charts published under the Documents tab. Includes 5x8 start-up service.
  • Efficient power management
    The Schneider Electric Easy UPS 3M offers an eco-mode for energy savings and supports VRLA batteries, ensuring efficient power management and sustainability.
  • Advanced connectivity
    Featuring a touchscreen LCD display for easy monitoring and control, along with a comprehensive suite of compliant standards including IEC and RoHS, this UPS ensures your equipment stays protected in a variety of environments.
  • Reliable performance
    With a power capacity of 60 kW and the ability to operate in temperatures ranging from 0°C to 40°C, the E3MUPS60KHBS provides reliable performance even in demanding conditions.
  • Enhanced safety features
    Built-in static bypass, audible and visible alarms keep you informed of any issues, ensuring your setup remains safe under all circumstances.
  • Flexible installation options
    The external form factor and hardwire 5-wire input connector type allow for flexible installation options, making it suitable for a wide range of applications.
Schneider Electric Easy UPS 3M E3MUPS60KHBS - UPS - 60 kW - 60000 VA
UPS - external
Bundled Services
Start-Up Service 5X8
311 kg
Input Wiring
3-phase
Input Voltage
AC 380/400/415 V
Output Voltage
AC 380/400/415 V ± 3%
Power Capacity
60 kW / 60000 VA
Input Connectors
Hardwire 5-wire (3PH + N + G)
No battery
Dust filter
White
60 cm x 100 cm x 197 cm
1-year warranty
UPS - external
Bundled Services
White
UPS Technology
On-line
Input Voltage
AC 380/400/415 V
Input Voltage Range
AC 342 - 477 V
Frequency Provided
50/60 Hz
Input Wiring
3-phase
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 380/400/415 V ± 3% - 50/60 Hz
Power Capacity
60 kW / 60000 VA
Output Waveform
Sinewave
No battery
Dust filter
Touch screen interface, audible alarm, built-in static bypass, touch screen LCD display, Eco-Mode, visible alarm, VRLA battery support
IEC 62040-3, IEC 62040-1-1, IEC 62040-2, RoHS, WEEE, REACH, IP20, EAC, RCM, ISTA 2B, IEC 62040-4
Limited warranty - 1 year - on-site
0 - 95% (non-condensing)
Sound Emission
65 dBA
60 cm
100 cm
197 cm
311 kg
Shipping Width
75 cm
Shipping Depth
112.5 cm
Shipping Height
210.2 cm
Shipping Weight
360 kg
Power Rating: 60kW
Brand: APC
Price Range Ex VAT: £1500+
