APC Dry Contact I/O SmartSlot Card
Quicklinx: B7ZGWS00 Mfr#: AP9613
Type: Module
Power Rating: [N/A]
£175.12 ex VAT
£210.14 inc VAT
Expandable input and output ports supports the temperature sensor, temperature and humidity sensor and dry contact I/O accessory.
Monitor external devices to trigger actions such as notifications or a change in output relay state with custom delay.
  • Compatible with SmartSlot enabled UPSs
    Compatible with all SmartSlot UPSs
  • Expandable Input and Output Ports
    Supports the Temperature Sensor, Temperature and Humidity Sensor and Dry Contact I/O Accessory
  • Input Output Interaction
    Enables interaction between device events (Inputs) and control actions (Outputs)
  • Configuration Utility
    Configure all actions with the easy to use configuration utility available on the card
  • 4 Configurable Input Contacts
  • 6 Configurable Output Relays
    In response to the UPS or input contacts changing states, and optionally including a customizable delay, trigger actions on external devices
  • Optional Dry Contact I/O Accessory
    Each Dry Contact I/O Accessory increases the number of input contacts by 2 and output relays by 1
Schneider Dry Contact I/O SmartSlot Card - UPS management module
Package Content
USB cable
12.1 cm x 11.4 cm x 3.8 cm
210 g
P/N: SCL500RM1UC, SCL500RM1UNC, SMT1000JOS6, SMTL1000RM2UC, SMTL1000RMI2UC, SMTL750RMI2UC, SMX1000C, SMX1500RM2UC, SMX1500RM2UCNC, SMX2KR2UNCX145, SMX750C, SMX750CNC, SRT1000XLJ, SRT10KXLTW, SRT1500XLJ, SRT2200XLI-KR, SRT2400XLJ, SRT3000XLA-TW, SRT3000XLTW, SRT5KRMXLW-TW, SRT6KXLTW, SRT8KXLJ
Package Content
USB cable
12.1 cm
11.4 cm
3.8 cm
210 g
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, RoHS, FCC Part 15 A, REACH
Limited warranty: replacement - 2 years
P/N: G35T15K3IS, G35T40K3IS, SCL500RM1UC, SCL500RM1UNC, SMT1000C, SMT1000I-AR, SMT1000IC, SMT1000JOS6, SMT1000R2I-AR, SMT1000RM2UC, SMT1000RMI2UC, SMT1500C, SMT1500I-AR, SMT1500IC, SMT1500NC, SMT1500R2I-AR, SMT1500RM2UC, SMT1500RM2UNC, SMT1500RMI2UC, SMT1500RMI2UNC, SMT2200C, SMT2200I2U-BR, SMT2200I-AR, SMT2200IC, SMT2200R2I-AR, SMT2200RM2UC, SMT2200RM2UNC, SMT2200RMI2UC, SMT2200RMI2UNC, SMT30002U-BR, SMT3000C, SMT3000I2U-BR, SMT3000I-AR, SMT3000IC, SMT3000R2I-AR, SMT3000RM2UC, SMT3000RM2UNC, SMT3000RMI2UC, SMT3000RMI2UNC, SMT750C, SMT750RM2UC, SMT750RM2UNC, SMT750RMI2UC, SMT750RMI2UNC, SMTL1000RM2UC, SMTL1000RMI2UC, SMTL750RM2UC, SMTL750RMI2UC, SMX1000C, SMX1000US, SMX1500RM2UC, SMX1500RM2UCNC, SMX1500RMNCUS, SMX1500RMUS, SMX2000LVNCUS, SMX2000LVUS, SMX2200HVNC, SMX2200RMLVUS, SMX2KR2UNCX145, SMX2KRMLVNCUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LV2U-BR, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750C, SMX750CNC, SMX750INC, SMX750NC, SMX750US, SRC1KI, SRC1KUXI, SRC2000XLI-CC, SRC2KI, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1000XLA, SRT1000XLI, SRT1000XLJ, SRT10KXLTUS, SRT10KXLTW, SRT10RMXLIX806, SRT1500RMXLA, SRT1500RMXLA-NC, SRT1500RMXLI, SRT1500RMXLI-NC, SRT1500XLA, SRT1500XLI, SRT1500XLJ, SRT2200RMXLA, SRT2200RMXLA-NC, SRT2200RMXLAUS, SRT2200RMXLI-NC, SRT2200XLA, SRT2200XLI-KR, SRT2400XLJ, SRT3000RMXLA, SRT3000RMXLA-NC, SRT3000RMXLI-NC, SRT3000RMXLT-NC, SRT3000XLA, SRT3000XLA-TW, SRT3000XLAUS, SRT3000XLTW, SRT5KRMXLTUS, SRT5KRMXLW-TW, SRT5KXLJ, SRT5KXLTUS, SRT6KRMXLIM, SRT6KXLTUS, SRT6KXLTW, SRT8KXLJ, SRT8KXLTUS, SRTL1000RMXLI, SRTL1000RMXLI-NC, SRTL1500RMXLI, SRTL1500RMXLI-NC, SRTL2200RMXLI, SRTL2200RMXLI-NC, SRTL3000RMXLI, SRTL3000RMXLI-NC, SUA1500I-IN, SUA3000I-IN, SURT20KUXI-IN, SURTA2200RMXL2U-NC, SY16K48H-PDNB, SY30K40E, SY32K48H-PDNB, SY48K48H-PDNB, SYA12K16IXRCH, SYA8K16PX798, SYA8K16PXRX798, SYA8K8PX798, SYA8K8RMPNX424, SYAF16KRMICH, XU1K0JJXXRX-JP, XU750JJXXRX-JP
B7ZG C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
B7ZG APC Temperature and Humidity Sensor In Stock £149.59
Type: Module
Power Rating: [N/A]
Brand: APC
