APC Data Cbl part. passthru
Quicklinx: 79F0WS00 Mfr#: AR8173BLK
£112.81 ex VAT
£135.37 inc VAT
This Shielding Partition Pass-through provides cable pass-through, facilitates overhead cable management, and features protective grounding provisions and tool-less mounting.
  • Protective grounding provisions
    Safety protection against electric shock and reduction of EMI emissions. NetShelter Enclosures incorporate a series of ground studs within each enclosure, providing adequate means for grounding all loose sheet metal panels and/or internally rack-mounted equipment.
  • Facilitates overhead cable management
    Overhead cable troughs and partitions install toollessly on the roof of the enclosure eliminating the need for ceiling mounted or underfloor mounted cable trays. Cable troughs and partitions are designed to manage both power and data cables while maintaining separation.
APC - cable shielding partition
Cable shielding partition
73.2 cm x 7.1 cm x 12.2 cm
2.3 kg
NetShelter SX
73.2 cm
7.1 cm
12.2 cm
2.3 kg
APC NetShelter SX
Product Type: Cable shielding partition
Brand: APC
