The Back-UPS Pro family offers guaranteed power protection for high performance computer systems, routers/modems, external storage devices, game consoles and other electronics in your home or business. These UPSs supply electronics with abundant battery backup during outages and stabilize unsafe voltage levels.
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Battery replacement without tools
Enables fast battery replacement, lowering Mean Time to Repair (MTTR). -
Battery-protected and surge-only outlets
Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment -
Boost and Trim Automatic Voltage Regulation (AVR)
Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models). -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Dataline surge protection
Provides protection of connected equipment from power surges on the data lines. -
Disconnected battery notification
Warns when a battery is not available to provide backup power. -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
PowerChute Personal Edition OS Compatibility
This software supports numerous operating systems and processors. For further information, please click here. -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment. -
Sine wave output
Eliminates humming and heat generated when powering tube lights and fans -
USB connectivity
Provides management of the UPS via a USB port (not available on all models). -
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
- APC Back-UPS Pro BR1600SI - UPS - 960 Watt - 1600 VA
- UPS - external
- 12.5 kg
- Input Voltage
- AC 220-240 V
- Output Voltage
- AC 220-240 V
- Power Capacity
- 960 Watt / 1600 VA
- Input Connectors
- 1
- Output connectors
- 6 x power (UPS and surge) , 2 x power (surge)
- Battery
- Lead Acid - 260 Wh
- Batteries Qty
- 1
- Networking
- USB
- Black
- 10 cm x 36.8 cm x 26 cm
- 2-year warranty (European Union - 3 years)
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 220-240 V
- Input Voltage Range
- AC 176 - 294 V
- Frequency Required
- 50/60 Hz ± 3Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- AC 220-240 V
- Power Capacity
- Dataline Surge Protection
- Ethernet 10/100/1000Base-T - RJ-45 - 1 input line / 1 output line , Phone line - 1 input line / 1 output line
- Output Waveform
- Stepped approximation to a sinewave
- Quantity
- 1
- Technology
- Lead Acid
- Capacity
- 260 Wh
- Recharge Time
- 16 hours
- Sealed, leak-proof
- Remote Management Interface
- USB
- Management (USB)
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), overload protection, dataline protection
- IP20
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - replace or repair - 2 years , European Union: limited warranty - replace or repair - 3 years
- 0 °C
- 40 °C
- 10 cm
- 36.8 cm
- 26 cm
- 12.5 kg
APC Service Pack 1 Year Warranty Extension | In Stock | £44.61 |
APC Service Pack 3 Year Warranty Extension | In Stock | £106.63 |
