APC BR1600SI BACK UPS PRO BR1600SI 1600VA 8 Outlets
Quicklinx: FLV6WS00 Mfr#: BR1600SI
Power Rating: 960Watt
Hurry, only 2 left in stock!
£450.79 ex VAT
£540.94 inc VAT
The Back-UPS Pro family offers guaranteed power protection for high performance computer systems, routers/modems, external storage devices, game consoles and other electronics in your home or business. These UPSs supply electronics with abundant battery backup during outages and stabilize unsafe voltage levels.
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Battery replacement without tools
    Enables fast battery replacement, lowering Mean Time to Repair (MTTR).
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models).
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines.
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • PowerChute Personal Edition OS Compatibility
    This software supports numerous operating systems and processors. For further information, please click here.
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
  • Sine wave output
    Eliminates humming and heat generated when powering tube lights and fans
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models).
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
APC Back-UPS Pro BR1600SI - UPS - 960 Watt - 1600 VA
UPS - external
12.5 kg
Input Voltage
AC 220-240 V
Output Voltage
AC 220-240 V
Power Capacity
960 Watt / 1600 VA
Input Connectors
1
Output connectors
6 x power (UPS and surge) , 2 x power (surge)
Lead Acid - 260 Wh
Batteries Qty
1
USB
10 cm x 36.8 cm x 26 cm
2-year warranty (European Union - 3 years)
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 220-240 V
Input Voltage Range
AC 176 - 294 V
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
1
Output Voltage
AC 220-240 V
Power Capacity
960 Watt / 1600 VA
Dataline Surge Protection
Ethernet 10/100/1000Base-T - RJ-45 - 1 input line / 1 output line , Phone line - 1 input line / 1 output line
Output Waveform
Stepped approximation to a sinewave
Quantity
1
Lead Acid
260 Wh
Recharge Time
16 hours
Sealed, leak-proof
Remote Management Interface
USB
Management (USB)
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), overload protection, dataline protection
IP20
Software Included
APC PowerChute Personal Edition
Limited warranty - replace or repair - 2 years , European Union: limited warranty - replace or repair - 3 years
10 cm
36.8 cm
26 cm
12.5 kg
FLV6 APC Service Pack 1 Year Warranty Extension In Stock £44.04
FLV6 APC Service Pack 3 Year Warranty Extension In Stock £104.90
Brand: APC
