APC BR1200SI BACK UPS PRO BR1200SI 1200VA 8 Outlets
Quicklinx: FLV4WS00 Mfr#: BR1200SI
Power Rating: 720Watt
£347.55 ex VAT
£417.06 inc VAT
The Back-UPS Pro family offers guaranteed power protection for high performance computer systems, routers/modems, external storage devices, game consoles and other electronics in your home or business. These UPSs supply electronics with abundant battery backup during outages and stabilize unsafe voltage levels.
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Battery replacement without tools
    Enables fast battery replacement, lowering Mean Time to Repair (MTTR).
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models).
  • Building Wiring Fault Indicator
    This LED informs users of potentially dangerous wiring problems in the wall circuit.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines.
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • PowerChute Personal Edition OS Compatibility
    This software supports numerous operating systems and processors. For further information, please click here.
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
  • Sine wave output
    Eliminates humming and heat generated when powering tube lights and fans
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models).
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
APC Back-UPS Pro BR1200SI - UPS - 720 Watt - 1200 VA
UPS - external
11.7 kg
Input Voltage
AC 220-240 V
Output Voltage
AC 220-240 V
Power Capacity
720 Watt / 1200 VA
Input Connectors
1
Output connectors
6 x power (UPS and surge) , 2 x power (surge)
Lead Acid
Batteries Qty
1
USB
10 cm x 36.8 cm x 26 cm
2-year warranty (European Union - 3 years)
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 220-240 V
Input Voltage Range
AC 176 - 294 V
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
1
Output Voltage
AC 220-240 V
Power Capacity
720 Watt / 1200 VA
Dataline Surge Protection
Ethernet 10/100/1000Base-T - RJ-45 - 1 input line / 1 output line , Phone line - 1 input line / 1 output line
Output Waveform
Stepped approximation to a sinewave
Quantity
1
Lead Acid
Recharge Time
16 hours
Sealed
Remote Management Interface
USB
Management (USB)
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), overload protection, dataline protection
IP20
Software Included
APC PowerChute Personal Edition
Limited warranty - replace or repair - 2 years , European Union: limited warranty - replace or repair - 3 years
10 cm
36.8 cm
26 cm
11.7 kg
FLV4 APC Service Pack 1 Year Warranty Extension In Stock £44.97
Brand: APC
