The Back-UPS Pro family offers guaranteed power protection for high performance computer systems, routers/modems, external storage devices, game consoles and other electronics in your home or business. These UPSs supply electronics with abundant battery backup during outages and stabilize unsafe voltage levels.
                Audible alarmsProvides notification of changing utility power and UPS power conditions
                Automatic self-testPeriodic battery self-test ensures early detection of a battery that needs to be replaced.
                Battery failure notificationProvides early-warning fault analysis on batteries enabling timely preventive maintenance
                Battery replacement without toolsEnables fast battery replacement, lowering Mean Time to Repair (MTTR).
                Battery-protected and surge-only outletsReserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
                Boost and Trim Automatic Voltage Regulation (AVR)Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models).
                Building Wiring Fault IndicatorThis LED informs users of potentially dangerous wiring problems in the wall circuit.
                Cold-start capableProvides temporary battery power when the utility power is out.
                Dataline surge protectionProvides protection of connected equipment from power surges on the data lines.
                Disconnected battery notificationWarns when a battery is not available to provide backup power.
                Hot-swappable batteriesEnsures clean, uninterrupted power to protected equipment while batteries are being replaced
                LCD graphics displayText and mimic diagrams that display modes of operation, system parameters and alarms.
                PowerChute Personal Edition OS CompatibilityThis software supports numerous operating systems and processors. For further information, please click here.
                Safety-agency approvedEnsures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
                Sine wave outputEliminates humming and heat generated when powering tube lights and fans
                USB connectivityProvides management of the UPS via a USB port (not available on all models).
                User-replaceable batteriesIncreases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
- APC Back-UPS Pro BR1200SI - UPS - 720 Watt - 1200 VA
- UPS - external
- 11.7 kg
- Input Voltage
- AC 220-240 V
- Output Voltage
- AC 220-240 V
- Power Capacity
- 720 Watt / 1200 VA
- Input Connectors
- 1
- Output connectors
- 6 x power (UPS and surge) , 2 x power (surge)
- Battery
- Lead Acid
- Batteries Qty
- 1
- Networking
- USB
- Black
- 10 cm x 36.8 cm x 26 cm
- 2-year warranty (European Union - 3 years)
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 220-240 V
- Input Voltage Range
- AC 176 - 294 V
- Frequency Required
- 50/60 Hz ± 3Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- AC 220-240 V
- Power Capacity
- Dataline Surge Protection
- Ethernet 10/100/1000Base-T - RJ-45 - 1 input line / 1 output line , Phone line - 1 input line / 1 output line
- Output Waveform
- Stepped approximation to a sinewave
- Quantity
- 1
- Technology
- Lead Acid
- Recharge Time
- 16 hours
- Sealed
- Remote Management Interface
- USB
- Management (USB)
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), overload protection, dataline protection
- IP20
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - replace or repair - 2 years , European Union: limited warranty - replace or repair - 3 years
- 0 °C
- 40 °C
- 10 cm
- 36.8 cm
- 26 cm
- 11.7 kg
|  | APC Service Pack 1 Year Warranty Extension | In Stock | £44.46 |
