APC Battery Pack Extension Cab
Quicklinx: 7K0DWS00 Mfr#: sua039
The APC Smart-UPS XL battery pack extension cable features Quick Plug-in Connections and is designed for SUA48 series battery packs.
  • Efficient power management
    The APC battery cable is designed for seamless integration with PC systems, ensuring efficient power management and reliable performance.
  • Durable construction
    Crafted with durability in mind, this power cable is built to withstand the rigors of daily use, providing a dependable connection for your power needs.
APC - battery cable
Battery cable
P/N: SUA2200R3XLNETPKG, SUA2200RMXLI3U, SUA2200UXICH, SUA2200XL, SUA2200XLI, SUA2200XL-NETPKG, SUA3000R3XLNETPKG, SUA3000RMXL3U-BR, SUA3000RMXLA3U, SUA3000RMXLI3U, SUA3000RMXLJ3U, SUA3000UXICH, SUA3000XL, SUA3000XLI, SUA3000XL-NETPKG, SUA3000XLT, SUA48RMXLBP, SUA48RMXLBP3U-TU, SUA48XLBP, UXABP48
Battery cable
P/N: SUA2200R3XLNETPKG, SUA2200RMXL3U, SUA2200RMXLI3U, SUA2200UXICH, SUA2200XL, SUA2200XLI, SUA2200XL-NETPKG, SUA3000R3XLNETPKG, SUA3000RMXL3U, SUA3000RMXL3U-BR, SUA3000RMXLA3U, SUA3000RMXLI3U, SUA3000RMXLJ3U, SUA3000UXICH, SUA3000XL, SUA3000XLI, SUA3000XL-NETPKG, SUA3000XLT, SUA48RMXLBP, SUA48RMXLBP3U, SUA48RMXLBP3U-TU, SUA48XLBP, UXABP48
