Uniquely designed to accept input power from any single phase, 120V power source such as a UPS, solar panel or other alternative energy power inputs. Reserves power capacity and run time for connected equipment that require battery back-up while providing surge only protection for less critical equipment. Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
UPS compatible
- APC Back-UPS Pro Battery Pack 24V - battery enclosure - Lead Acid
- Battery enclosure - external
- 13.4 kg
- Input Voltage
- 12 V
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 2
- Black
- 11.2 cm x 38.2 cm x 30.1 cm
- 2-year warranty
- Designed For
- P/N: BR1500, BR1500G, BR1500G-BR, BR1500G-CN, BR1500G-FR, BR1500G-GR, BR1500GI, BR1500I
- Battery Enclosure Type
- Internal
- Black
- Input Voltage
- 12 V
- Quantity
- 2
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- TUV, RoHS
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 11.2 cm
- 38.2 cm
- 30.1 cm
- 13.4 kg
- Shipping Width
- 22.9 cm
- Shipping Depth
- 48.3 cm
- Shipping Height
- 38.1 cm
- Shipping Weight
- 13.4 kg
- Designed For
APC Service Pack 1 Year Warranty Extension | In Stock | £44.34 |
APC Service Pack 3 Year Warranty Extension | In Stock | £104.39 |
