The APC Back-UPS Pro models provide premium battery backup and surge protection. Ideal for home or small office electronics, networking devices, gaming PCs and consoles. APC Back-UPS Pro models provide sinewave output, USB charging ports for your mobile devices, and increased runtime for your critical electronics.
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Battery replacement without tools
Enables fast battery replacement, lowering Mean Time to Repair (MTTR). -
Battery-protected and surge-only outlets
Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment -
Boost and Trim Automatic Voltage Regulation (AVR)
Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models). -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Dataline surge protection
Provides protection of connected equipment from power surges on the data lines. -
Disconnected battery notification
Warns when a battery is not available to provide backup power. -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment. -
USB connectivity
Provides management of the UPS via a USB port (not available on all models). -
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
- APC Back-UPS Pro BR900MI - UPS - 540 Watt - 900 VA
- UPS - external
- 7 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 8%
- Power Capacity
- 540 Watt / 900 VA
- Input Connectors
- 1
- Output connectors
- 6 x power (UPS and surge)
- Battery
- Lead Acid
- Run Time (Up To)
- 3 min at full load
- Networking
- USB
- Black
- 9.1 cm x 31 cm x 19 cm
- 2-year warranty (European Union - 3 years)
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 176 - 294 V
- Frequency Provided
- 50/60 Hz ± 1Hz
- Frequency Required
- 50/60 Hz ± 3Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 8% - 50/60 Hz
- Power Capacity
- 540 Watt / 900 VA
- Dataline Surge Protection
- Ethernet 10/100/1000Base-T - RJ-45 - 1 input line / 1 output line , Phone line - 1 input line / 1 output line
- Output Waveform
- Stepped approximation to a sinewave
- Surge Energy Rating
- 557 Joules
- Circuit Protection
- Circuit breaker
- Power Factor (PF)
- 0.6
- Technology
- Lead Acid
- Run Time (Up To)
- 3 min at full load , 11.4 min at half load , 8 min at 335 Watts , 14 min at 240 Watts , 34 min at 119 Watts , 105 min at 40 Watts
- Recharge Time
- 12 hours
- Remote Management Interface
- USB
- Management (USB)
- Cables Included
- Power cable 1.83 m , USB cable
- Equipment Protection Value
- 150000 Euros
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), overload protection, dataline protection
- TUV GS, EMC, IP20, KETI, EAC, RCM, TISI, CB 60950
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - replace or repair - 2 years , European Union: limited warranty - replace or repair - 3 years
- 0 °C
- 40 °C
- 9.1 cm
- 31 cm
- 19 cm
- 7 kg
- Shipping Width
- 44 cm
- Shipping Depth
- 14.3 cm
- Shipping Height
- 25.5 cm
- Shipping Weight
- 8 kg
APC Service Pack 1 Year Warranty Extension | In Stock | £49.36 |
