APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
Reliable power protection
The APC SurgeArrest 325 UPS offers dependable power protection and battery backup for your computing needs, ensuring your PC remains operational during power disruptions. -
Comprehensive connectivity
Equipped with 4 output connectors and a dedicated RJ-11 dataline surge protection, this UPS safeguards not only your power supply but also your phone line against surges. -
Efficient environmental adaptability
Designed to operate under a wide range of environmental conditions, this UPS maintains performance reliability with an operating humidity range of 0 - 95% and temperature tolerance from 0°C to 40°C.
- APC SurgeArrest 325 - UPS - 325 VA
- UPS - external
- 4 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 325 VA
- Input Connectors
- 1
- Output connectors
- 4 x power
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- 11.5 cm x 36.4 cm x 9.5 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Localisation
- United Kingdom
- Supported Battery Technology
- Lead Acid
- Input Voltage
- AC 230 V
- Frequency Provided
- 50 Hz
- Frequency Required
- 47 - 53 Hz
- Input Connectors
- 1
- Power Output Connectors Details
- 4 x power
- Output Voltage
- AC 230 V 50 Hz
- Power Capacity
- 325 VA
- Dataline Surge Protection
- Phone line - RJ-11
- Surge Suppression
- Technology
- Lead Acid
- Recharge Time
- 16 hours
- Cables Included
- Power cable - integrated
- IEC 60950, EN55022 Class B, EN 50091-2
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 11.5 cm
- 36.4 cm
- 9.5 cm
- 4 kg
