APC Back-UPS ES 400 - UPS - 400 VA - AC 230V - 8 Output Connectors
Customer rating: 3.0* (Write a review)
Quicklinx: 44PVWS00 Mfr#: BE400-UK
Type: UPS
Power Rating: 400VA
Hurry, only 3 left in stock!
£80.23 ex VAT
£96.27 inc VAT
The Back-UPS ES offers affordable battery backup and surge protection for home computers. With enough power outlets to protect your entire system, built-in phone/fax/modem line (DSL compatible) protection make this power protection solution the best value for home and home office computers.
APC Back-UPS ES, 240 Watts / 400 VA,Input 230V / Output 230V Includes: User Manual, Wall-mounting template
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Resettable circuit breaker
    Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs)
UPS - external
5.4 kg
United Kingdom
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
400 VA
Input Connectors
1 x power BS 1363
Output connectors
4 x power BS 1363 (surge) , 4 x power BS 1363 (UPS and surge)
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
5.2 min at full load
Charcoal
23 cm x 28.5 cm x 8.6 cm
3-year warranty
UPS - external
Battery Enclosure Type
Internal
Charcoal
United Kingdom
UPS Technology
Off-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power BS 1363
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
400 VA
Dataline Surge Protection
Network/phone line - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
310 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
16 hours
Power cable 1.8 m
Equipment Protection Value
50000 British Pounds
Wall mountable, audible alarm, LED indicators
UL 1449
Limited warranty - 3 years
0 - 95%
Sound Emission
45 dBA
23 cm
28.5 cm
8.6 cm
5.4 kg
Resources
The following resources are available for the APC Back-UPS ES 400 - UPS - 400 VA - AC 230V - 8 Output Connectors
Customer reviews
Write a review for the APC Back-UPS ES 400 - UPS - 400 VA - AC 230V - 8 Output Connectors here!
No shut-down link
Reviewed by TC. Review Posted 24/05/2007
I know it doesn't say it does here, but this doesn't have a link cable and software to automatically shut down your PC if the power goes off. I bought this having read a review of the Back-UPS ES 700 which does (as does the 550 which is only £9 more). It is dead easy to use if you know how to plug things in. So buy a 550 or 700 model, some more time without power and automated shut down.
  • Overall 3*
  • Ease of use 5*
  • Value for money 2*
Do not buy for home use
Reviewed by Graham. Review Posted 14/05/2007
Great battery back-up unit, but do not buy for home use. On power outage the lound alarm goes off every 30 seconds, and cannot be disabled.
In a normal home this is easily loud enough to wake up the whole household, and keep them awake until the power returns!
On this model you cannot disable the alarm, the models up the range can be configured thru the USB connection and supplied software to disable the alarm.
I returned mine for the 700VA model.
  • Overall 3*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: UPS
Power Rating: 400VA
Brand: APC
Price Range Ex VAT: 50 - 100
