The Back-UPS ES offers affordable battery backup and surge protection for home computers. With enough power outlets to protect your entire system, built-in phone/fax/modem line (DSL compatible) protection make this power protection solution the best value for home and home office computers.
APC Back-UPS ES, 240 Watts / 400 VA,Input 230V / Output 230V Includes: User Manual, Wall-mounting template
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR) -
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment -
Battery-protected and surge-only outlets
Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment -
Resettable circuit breaker
Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs)
- APC Back-UPS ES 400 - UPS - 400 VA
- UPS - external
- 5.4 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 400 VA
- Input Connectors
- 1 x power BS 1363
- Output connectors
- 4 x power BS 1363 (surge) , 4 x power BS 1363 (UPS and surge)
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 5.2 min at full load
- Charcoal
- 23 cm x 28.5 cm x 8.6 cm
- 3-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Charcoal
- Localisation
- United Kingdom
- UPS Technology
- Off-line
- Input Voltage
- AC 230 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power BS 1363
- Power Output Connectors Details
- Output Voltage
- AC 230 V 50/60 Hz
- Power Capacity
- 400 VA
- Dataline Surge Protection
- Network/phone line - RJ-45
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 310 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 16 hours
- Cables Included
- Power cable 1.8 m
- Equipment Protection Value
- 50000 British Pounds
- Wall mountable, audible alarm, LED indicators
- UL 1449
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 23 cm
- 28.5 cm
- 8.6 cm
- 5.4 kg
APC Replacement Battery Cartridge | In Stock | £54.25 |
Resources
The following resources are available for the APC Back-UPS ES 400 - UPS - 400 VA - AC 230V - 8 Output Connectors
Customer reviews
Write a review for the APC Back-UPS ES 400 - UPS - 400 VA - AC 230V - 8 Output Connectors here!
No shut-down link
Reviewed by TC. Review Posted 24/05/2007
I know it doesn't say it does here, but this doesn't have a link cable and software to automatically shut down your PC if the power goes off. I bought this having read a review of the Back-UPS ES 700 which does (as does the 550 which is only £9 more). It is dead easy to use if you know how to plug things in. So buy a 550 or 700 model, some more time without power and automated shut down.
Overall
Ease of use
Value for money
Do not buy for home use
Reviewed by Graham. Review Posted 14/05/2007
Great battery back-up unit, but do not buy for home use. On power outage the lound alarm goes off every 30 seconds, and cannot be disabled.
In a normal home this is easily loud enough to wake up the whole household, and keep them awake until the power returns!
On this model you cannot disable the alarm, the models up the range can be configured thru the USB connection and supplied software to disable the alarm.
I returned mine for the 700VA model.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
