The Back-UPS CS provides professional-grade power protection for office and home office systems. Battery powered & surge protected power outlets, built-in phone/fax/modem line (DSL compatible) protection, safe system shutdown software with sophisticated power management features and pro-active audio-visual status indicators ensure office systems and their valuable data are protected from dangerous power surges, spikes and blackouts. Easy access to a hot-swappable, user-replaceable battery also makes servicing the Back-UPS CS hassle-free. These features along with its classic styling make the Back-UPS CS a perfect choice for protecting your important office and home office systems.
Serial connectivity
Use any Home Automation network to monitor and control the S20 through its RS-232 serial port. For information on how to communicate with the S20, see APC's Application Note #102. Crestron and AMX installers should visit their respective websites for information on how to integrate the S20 into those networks. -
Serial connectivity
Provides management of the UPS via a serial port. -
USB connectivity
Provides management of the UPS via a USB port (not available on all models).
- APC Back-UPS CS 500 - UPS - 300 watt - 500 VA
- UPS - external
- 6 kg
- Load Rating
- Individual PC
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 8%
- Power Capacity
- 300 watt / 500 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 1 x power IEC 60320 C13 (surge) , 3 x power IEC 60320 C13 (UPS and surge)
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 2.4 min at full load
- Networking
- RS-232, USB
- Beige
- System Requirements
- Apple MacOS 9, Apple MacOS 9.0.4 or later, Microsoft Windows 98/ME/2000/XP
- 9.1 cm x 28.4 cm x 16.5 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Beige
- Load Rating
- Individual PC
- UPS Technology
- Off-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 196 - 280 V
- Input Voltage Range (Adjustable)
- AC 160 - 300 V
- Input Voltage Margin
- ± 5%
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 8%
- Power Capacity
- 300 watt / 500 VA
- Dataline Surge Protection
- Phone line - RJ-11
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 300 joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 8 hours
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232/USB) - RJ-45
- Cables Included
- USB cable - external
- Equipment Protection Value
- 100000 Euros
- LED display, audible alarm
- C-Tick, GOST, UL 1449, VDE, EN 50091-2, EN 50091-1
- Software Included
- APC PowerChute Personal Edition
- OS Required
- Limited warranty - replace or repair - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -15 °C
- Max Storage Temperature
- 45 °C
- 0 - 95%
- Humidity Range Storage
- 0 - 95%
- Sound Emission
- 40 dBA
- 9.1 cm
- 28.4 cm
- 16.5 cm
- 6 kg
- Shipping Width
- 24.1 cm
- Shipping Depth
- 36.8 cm
- Shipping Height
- 17.8 cm
- Shipping Weight
- 7.1 kg
Customer reviews
Write a review for the APC Back-UPS CS 500Ei here!
very happy
Reviewed by Sean. Review Posted 17/01/2008
I'm very pleased with this unit
It works on Linux with the NUT driver version 2.0.4 - no need for the supplied disk.
Powering my desktop and monitor it is reporting 25% load with a predicted runtime on battery of 45minutes!
I'm not quite convinced by that runtime - but it is certainly ample time for a safe system shutdown.
Overall
Ease of use
Value for money
Sockets
Reviewed by Rich. Review Posted 01/02/2007
In response to Francis, most computer ups do not have uk mains type sockets on them, they have the universal 3 pin sockets for the standard computer power cables, which you might find you have to go out and buy. eg: Quicklinx 3ZMRWS
Overall
Ease of use
Value for money
APC are the best
Reviewed by Mark. Review Posted 06/06/2006
This may not have come with a mains cable - you use the one that your PC has now. The connectors are straight through male/female connectors. Unless the last reviewer had one designed for abroad then you should have no problem. I have bought a number of APC UPS's in the past and they are worth every penny. (You normally get two straight through leads with the UPS - enough for tower and monitor
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
