APC Back-UPS CS 500Ei
Customer rating: 5.0* (Write a review)
Quicklinx: XK0WS00 Mfr#: BK500EI
Type: UPS
Power Rating: 300Watt
31 In Stock
£122.85 ex VAT
£147.42 inc VAT
The Back-UPS CS provides professional-grade power protection for office and home office systems. Battery powered & surge protected power outlets, built-in phone/fax/modem line (DSL compatible) protection, safe system shutdown software with sophisticated power management features and pro-active audio-visual status indicators ensure office systems and their valuable data are protected from dangerous power surges, spikes and blackouts. Easy access to a hot-swappable, user-replaceable battery also makes servicing the Back-UPS CS hassle-free. These features along with its classic styling make the Back-UPS CS a perfect choice for protecting your important office and home office systems.
  • Serial connectivity
    Use any Home Automation network to monitor and control the S20 through its RS-232 serial port. For information on how to communicate with the S20, see APC's Application Note #102. Crestron and AMX installers should visit their respective websites for information on how to integrate the S20 into those networks.
    Provides management of the UPS via a serial port.
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models).
APC Back-UPS CS 500 - UPS - 300 Watt - 500 VA
UPS - external
6 kg
Load Rating
Individual PC
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 8%
Power Capacity
300 Watt / 500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
1 x power IEC 60320 C13 (surge) , 3 x power IEC 60320 C13 (UPS and surge)
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
2.4 min at full load
RS-232, USB
Beige
Apple MacOS 9, Apple MacOS 9.0.4 or later, Microsoft Windows 98/ME/2000/XP
9.1 cm x 28.4 cm x 16.5 cm
UPS - external
Battery Enclosure Type
Internal
Beige
Load Rating
Individual PC
UPS Technology
Off-line
Input Voltage
AC 230 V
Input Voltage Range
AC 196 - 280 V
Input Voltage Range (Adjustable)
AC 160 - 300 V
Input Voltage Margin
± 5%
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 8%
Power Capacity
300 Watt / 500 VA
Dataline Surge Protection
Phone line - RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
300 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
8 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232/USB) - RJ-45
USB cable - external
Equipment Protection Value
100000 Euros
LED display, audible alarm
C-Tick, GOST, UL 1449, VDE, EN 50091-2, EN 50091-1
Software Included
APC PowerChute Personal Edition
Limited warranty - replace or repair - 2 years
Min Storage Temperature
-15 °C
Max Storage Temperature
45 °C
0 - 95%
Humidity Range Storage
0 - 95%
Sound Emission
40 dBA
9.1 cm
28.4 cm
16.5 cm
6 kg
Shipping Width
24.1 cm
Shipping Depth
36.8 cm
Shipping Height
17.8 cm
Shipping Weight
7.1 kg
XK0 APC BackUPS 250/280/400 Replacement Battery Cartridge In Stock £60.80
Customer reviews
Write a review for the APC Back-UPS CS 500Ei here!
very happy
Reviewed by Sean. Review Posted 17/01/2008
I'm very pleased with this unit
It works on Linux with the NUT driver version 2.0.4 - no need for the supplied disk.
Powering my desktop and monitor it is reporting 25% load with a predicted runtime on battery of 45minutes!
I'm not quite convinced by that runtime - but it is certainly ample time for a safe system shutdown.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Sockets
Reviewed by Rich. Review Posted 01/02/2007
In response to Francis, most computer ups do not have uk mains type sockets on them, they have the universal 3 pin sockets for the standard computer power cables, which you might find you have to go out and buy. eg: Quicklinx 3ZMRWS
  • Overall 5*
  • Ease of use 5*
APC are the best
Reviewed by Mark. Review Posted 06/06/2006
This may not have come with a mains cable - you use the one that your PC has now. The connectors are straight through male/female connectors. Unless the last reviewer had one designed for abroad then you should have no problem. I have bought a number of APC UPS's in the past and they are worth every penny. (You normally get two straight through leads with the UPS - enough for tower and monitor
  • Overall 5*
  • Ease of use 5*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: UPS
Brand: APC
