APC BACK-UPS CS 325VA 230V
Quicklinx: GDZZWS00 Mfr#: BK325I
Power Rating: 210Watt
£74.53 ex VAT
£89.43 inc VAT
The Back-UPS CS offers best value for protecting your business and office computer systems. It provides battery backup power that allows you to work through short and medium length power outages. It also safeguards your equipment from damaging surges and spikes. Additional features like audible alarms, LED status indicators, user replaceable battery, push-button circuit breakers and transformer-block spaced outlets make the Back-UPS CS the perfect unit to protect your business' productivity from the constant threat of power outages and lost data.
  • Data line surge protection
    Protects connected loads from surges, spikes, lightning, and other power disturbances.
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require battery back-up while providing surge only protection for less critical equipment.
  • LED status indicators
    Quickly understand unit and power status with visual indicators.
  • Audible alarms
    Provides notification of changing utility power and UPS conditions.
  • Transformer-block spaced outlets
    Protect equipment with input transformer blocks without blocking access to other receptacles.
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Battery replacement without tools
    Allows quick, easy battery replacement.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced.
  • Automatic restart of loads after UPS shutdown
    Automatically starts up the connected equipment upon the return of utility power.
  • Resettable circuit breakers
    Enables a quick recovery from overload events.
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment. UL, FCC, CE, C-Tick approvals.
APC Back-UPS CS 325 - UPS - 210 Watt - 350 VA
UPS - external
5.7 kg
Load Rating
Individual PC
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
210 Watt / 350 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
1 x power IEC 60320 C13 (surge) , 3 x power IEC 60320 C13 (UPS and surge)
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
1
Run Time (Up To)
6.6 min at full load
Beige
9.1 cm x 28.4 cm x 16.5 cm
UPS - external
Battery Enclosure Type
Plug-in module
Beige
Load Rating
Individual PC
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Input Voltage Range
AC 196 - 280 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V
Power Capacity
210 Watt / 350 VA
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
320 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
6 hours
2 x power cable - external
Audible alarm
C-Tick, GOST, PCBC, UL 1449, VDE, EN 50091-2, EN 50091-1
Limited warranty - parts and labour - 2 years
Min Storage Temperature
-15 °C
Max Storage Temperature
45 °C
0 - 95%
Humidity Range Storage
0 - 95%
9.1 cm
28.4 cm
16.5 cm
5.7 kg
GDZZ APC BackUPS 250/280/400 Replacement Battery Cartridge In Stock £60.26
Brand: APC
