The Back-UPS CS offers best value for protecting your business and office computer systems. It provides battery backup power that allows you to work through short and medium length power outages. It also safeguards your equipment from damaging surges and spikes. Additional features like audible alarms, LED status indicators, user replaceable battery, push-button circuit breakers and transformer-block spaced outlets make the Back-UPS CS the perfect unit to protect your business' productivity from the constant threat of power outages and lost data.
Data line surge protection
Protects connected loads from surges, spikes, lightning, and other power disturbances. -
Battery-protected and surge-only outlets
Reserves power capacity and run time for connected equipment that require battery back-up while providing surge only protection for less critical equipment. -
Quickly understand unit and power status with visual indicators. -
Audible alarms
Provides notification of changing utility power and UPS conditions. -
Transformer-block spaced outlets
Protect equipment with input transformer blocks without blocking access to other receptacles. -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced. -
Battery replacement without tools
Allows quick, easy battery replacement. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced. -
Automatic restart of loads after UPS shutdown
Automatically starts up the connected equipment upon the return of utility power. -
Resettable circuit breakers
Enables a quick recovery from overload events. -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment. UL, FCC, CE, C-Tick approvals.
- APC Back-UPS CS 325 - UPS - 210 watt - 350 VA
- UPS - external
- 5.7 kg
- Load Rating
- Individual PC
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 210 watt / 350 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 1 x power IEC 60320 C13 (surge) , 3 x power IEC 60320 C13 (UPS and surge)
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Batteries Qty
- 1
- Run Time (Up To)
- 6.6 min at full load
- Beige
- 9.1 cm x 28.4 cm x 16.5 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Plug-in module
- Beige
- Load Rating
- Individual PC
- Supported Battery Technology
- Lead Acid
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 196 - 280 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Power Capacity
- 210 watt / 350 VA
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 320 joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 6 hours
- Cables Included
- 2 x power cable - external
- Audible alarm
- C-Tick, GOST, PCBC, UL 1449, VDE, EN 50091-2, EN 50091-1
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -15 °C
- Max Storage Temperature
- 45 °C
- 0 - 95%
- Humidity Range Storage
- 0 - 95%
- 9.1 cm
- 28.4 cm
- 16.5 cm
- 5.7 kg
APC BackUPS 250/280/400 Replacement Battery Cartridge | In Stock | £61.11 |
