Adjustable voltage sensitivity
Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications. -
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced. -
Battery charging indicator
Lets you know when your battery is charging and when it is fully charged. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Building Wiring Fault Indicator
This LED informs users of potentially dangerous wiring problems in the wall circuit. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Dataline surge protection
Provides protection of connected equipment from power surges on the data lines. -
Disconnected battery notification
Warns when a battery is not available to provide backup power. -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment. -
Simple battery replacement
Increases UPS availability by allowing quick, easy battery replacement. -
USB charging ports
Simultaneously charge mobile devices, including smartphones and tablets. -
USB connection
Use your PC to access additional power protection and management features for your UPS via a USB Port. -
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
 - APC Back-UPS BE850G2 - UPS - 520 Watt - 850 VA
 - UPS - external
 - 4.5 kg
- Localisation
 - United Kingdom
- Input Voltage
 - AC 230 V
- Output Voltage
 - AC 230 V
- Power Capacity
 - 520 Watt / 850 VA
- Input Connectors
 - 1 x power BS 1363A
- Output connectors
 - 6 x power (UPS and surge) , 2 x power (surge) , 1 x 4 pin USB Type A 2.4 A , 1 x 24 pin USB-C
- Battery
 - Lead Acid
- Batteries Qty
 - 1
 - Black
 - 13 cm x 36.5 cm x 12 cm
 - 3-year warranty
 - UPS - external
 - Black
- Localisation
 - United Kingdom
- Input Voltage
 - AC 230 V
- Frequency Required
 - 47 - 63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
 - AC 230 V
- Power Capacity
 - 520 Watt / 850 VA
- Dataline Surge Protection
 - Network - RJ-45
- Output Waveform
 - Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
 - 310 Joules
- Circuit Protection
 - Circuit breaker
- Efficiency
 - 80%
- Power Factor (PF)
 - 0.612
- Quantity
 - 1
- Technology
 - Lead Acid
- Run Time (Up To)
 - 72 min at 50 Watts , 34.1 min at 100 Watts , 14.3 min at 200 Watts , 7.7 min at 300 Watts , 4.5 min at 400 Watts , 2.6 min at 500 Watts
- Cables Included
 - Power cable 1.83 m
- Equipment Protection Value
 - 100000 Euros
 - LED indicators, overload protection
 - EAC
- Software Included
 - APC PowerChute Personal Edition
 - Limited warranty - 3 years
 - 13 cm
 - 36.5 cm
 - 12 cm
 - 4.5 kg
- Shipping Width
 - 18.6 cm
- Shipping Depth
 - 44.1 cm
- Shipping Height
 - 19 cm
- Shipping Weight
 - 5 kg
                        APC Replacement Battery Cartridge RBC17 | In Stock | £59.00 |
