APC BACK-UPS BE850G2-UK 850VA 230V USB
Quicklinx: FLTWWS00 Mfr#: BE850G2-UK
Power Rating: 520watt
46 In Stock
£118.16 ex VAT
£141.79 inc VAT
Marketing description is not available.
  • Adjustable voltage sensitivity
    Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications.
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Battery charging indicator
    Lets you know when your battery is charging and when it is fully charged.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Building Wiring Fault Indicator
    This LED informs users of potentially dangerous wiring problems in the wall circuit.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines.
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
  • Simple battery replacement
    Increases UPS availability by allowing quick, easy battery replacement.
  • USB charging ports
    Simultaneously charge mobile devices, including smartphones and tablets.
  • USB connection
    Use your PC to access additional power protection and management features for your UPS via a USB Port.
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
APC Back-UPS BE850G2 - UPS - 520 watt - 850 VA
UPS - external
4.5 kg
United Kingdom
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
520 watt / 850 VA
Input Connectors
1 x power BS 1363A
Output connectors
6 x power (UPS and surge) , 2 x power (surge) , 1 x 4 pin USB Type A 2.4 A , 1 x 24 pin USB-C
Lead Acid
Batteries Qty
1
13 cm x 36.5 cm x 12 cm
3-year warranty
UPS - external
United Kingdom
Input Voltage
AC 230 V
Frequency Required
47 - 63 Hz
Input Connectors
1 x power BS 1363A
Output Voltage
AC 230 V
Power Capacity
520 watt / 850 VA
Dataline Surge Protection
Network - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
310 joules
Circuit Protection
Circuit breaker
Efficiency
80%
Power Factor (PF)
0.612
Quantity
1
Lead Acid
Run Time (Up To)
72 min at 50 Watts , 34.1 min at 100 Watts , 14.3 min at 200 Watts , 7.7 min at 300 Watts , 4.5 min at 400 Watts , 2.6 min at 500 Watts
Power cable 1.83 m
Equipment Protection Value
100000 Euros
Overload protection, LED indicators
EAC
Software Included
APC PowerChute Personal Edition
Limited warranty - 3 years
13 cm
36.5 cm
12 cm
4.5 kg
Shipping Width
18.6 cm
Shipping Depth
44.1 cm
Shipping Height
19 cm
Shipping Weight
5 kg
FLTW APC Replacement Battery Cartridge RBC17 In Stock £57.20
Brand: APC
