APC BACK-UPS BE650G2-UK 650VA 230V
Quicklinx: FLTTWS00 Mfr#: BE650G2-UK
Power Rating: 400watt
£108.75 ex VAT
£130.50 inc VAT
Marketing description is not available.
  • Adjustable voltage sensitivity
    Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications.
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Battery charging indicator
    Lets you know when your battery is charging and when it is fully charged.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Building Wiring Fault Indicator
    This LED informs users of potentially dangerous wiring problems in the wall circuit.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines.
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
  • Simple battery replacement
    Increases UPS availability by allowing quick, easy battery replacement.
  • USB connection
    Use your PC to access additional power protection and management features for your UPS via a USB Port.
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
APC Back-UPS BE650G2-UK - UPS - 400 watt - 650 VA
UPS - external
4 kg
United Kingdom
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
400 watt / 650 VA
Input Connectors
1 x power BS 1363A
Output connectors
6 x power (UPS and surge) , 2 x power (surge) , 1 x 4 pin USB Type A 2.4 A
Lead Acid
Batteries Qty
1
Run Time (Up To)
2.6 min at full load
13 cm x 36.5 cm x 12 cm
3-year warranty
UPS - external
United Kingdom
Input Voltage
AC 230 V
Input Voltage Range
AC 180 - 266 V
Frequency Provided
50/60 Hz
Frequency Required
47 - 63 Hz
Input Connectors
1 x power BS 1363A
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
400 watt / 650 VA
Dataline Surge Protection
Network - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
310 joules
Circuit Protection
Circuit breaker
Efficiency
80%
Quantity
1
Lead Acid
Run Time (Up To)
56.2 min at 50 Watts , 26 min at 100 Watts , 10.4 min at 200 Watts , 5.2 min at 300 Watts , 2.6 min at 400 Watts
Recharge Time
16 hours
Transfer Time
6 ms
Maintenance free, sealed
Power cable 1.83 m
Overload protection, audible alarm
IP20
Software Included
APC PowerChute Personal Edition
Limited warranty - 3 years
0 - 95% (non-condensing)
13 cm
36.5 cm
12 cm
4 kg
Shipping Width
18.6 cm
Shipping Depth
44.1 cm
Shipping Height
19 cm
Shipping Weight
4.5 kg
FLTT APC Replacement Battery Cartridge #110 In Stock £56.24
Brand: APC
