APC Back-UPS 950VA 480 Watt
Quicklinx: CDVGWS00 Mfr#: BX950UI
Power Rating: 480Watt
£107.69 ex VAT
£129.22 inc VAT
USB connection
Use your PC to access additional power protection and management features for your UPS via a USB Port.
Telephone dataline surge protection
Provides protection of connected equipment from power surges traveling on telephone lines.
Automatic Voltage Regulation (AVR)
Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment.
Resettable circuit breaker
Easy recovery from overloads; no need to replace a fuse.
Automatic restart of loads after UPS shutdown
Automatically starts up the connected equipment upon the return of utility power.
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Automatic self-test
  • Resettable circuit breaker
    Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs)
  • Automatic restart of loads after UPS shutdown
  • Automatic Voltage Regulation (AVR)
  • USB connection
  • Telephone dataline surge protection
APC Back-UPS 950VA - UPS - 480 Watt - 950 VA
UPS - external
8 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
480 Watt / 950 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13 (UPS and surge)
Lead Acid
Batteries Qty
1
Run Time (Up To)
1 min at full load
USB
13 cm x 33.6 cm x 21.5 cm
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 150 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
480 Watt / 950 VA
Dataline Surge Protection
Phone line - RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
273 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
1 min at full load , 8 min at half load
Recharge Time
8 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B
Power cable 1.22 m
Audible alarm, audible alarm, Automatic Voltage Regulation (AVR), LED indicators, automatic self-test
C-Tick, IEC 62040-1-1, RoHS, A-Tick, REACH, RCM
Software Included
APC PowerChute Personal Edition
Limited warranty - replace or repair - 2 years
0 - 95%
Sound Emission
45 dBA
13 cm
33.6 cm
21.5 cm
8 kg
Shipping Width
24.5 cm
Shipping Depth
44 cm
Shipping Height
29.5 cm
Shipping Weight
8.99 kg
CDVG APC Service Pack 1 Year Warranty Extension In Stock £49.50
Brand: APC
