APC Back-UPS 500 Structured Wiring UPS 230V
Quicklinx: 8TQHWS00 Mfr#: BH500INET
Type: UPS
Power Rating: 500VA
£135.02 ex VAT
£162.02 inc VAT
APC Back-UPS HS 500 is a compete management and power protection solution for structured wiring and home networking applications. It provides the flexibility to remotely manage the UPS and control the outlets via Web browser.
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
  • Network manageable
    Provides remote power management of the UPS over the network
  • Resettable circuit breaker
    Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs)
  • Transformer-block spaced outlets
    Protect equipment with input transformer blocks without blocking access to other receptacles
APC Back-UPS HS 500 - UPS - 500 VA
UPS - external
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
500 VA
Input Connectors
1 x power IEC 60320 C6
Output connectors
4 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
4.4 min at full load
Beige
22.5 cm x 10.5 cm x 37.2 cm
UPS - external
Beige
Input Voltage
AC 230 V
Frequency Required
47 - 63 Hz
Input Connectors
Output Voltage
AC 230 V
Power Capacity
500 VA
Dataline Surge Protection
Phone line - RJ-11 , Ethernet 10/100Base-TX - RJ-45 , Audio / video
Surge Suppression
Surge Energy Rating
600 Joules
Lead Acid
Run Time (Up To)
Network cable - external , Power cable - integrated - 2.44 m
LED display, audible alarm
FCC Class B certified, UL, cUL, FCC Part 68, IC
5 - 95%
22.5 cm
10.5 cm
37.2 cm
8TQH APC BackUPS 250/280/400 Replacement Battery Cartridge In Stock £60.26
Type: UPS
Power Rating: 500VA
Brand: APC
