APC Back-UPS HS 500 is a compete management and power protection solution for structured wiring and home networking applications. It provides the flexibility to remotely manage the UPS and control the outlets via Web browser.
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR) -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment -
Network manageable
Provides remote power management of the UPS over the network -
Resettable circuit breaker
Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs) -
Transformer-block spaced outlets
Protect equipment with input transformer blocks without blocking access to other receptacles
- APC Back-UPS HS 500 - UPS - 500 VA
- UPS - external
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 500 VA
- Input Connectors
- 1 x power IEC 60320 C6
- Output connectors
- 4 x power IEC 60320 C13
- Battery
- Lead Acid
- Run Time (Up To)
- 4.4 min at full load
- Beige
- 22.5 cm x 10.5 cm x 37.2 cm
- 2-year warranty
- UPS - external
- Beige
- Input Voltage
- AC 230 V
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Power Capacity
- 500 VA
- Dataline Surge Protection
- Phone line - RJ-11 , Ethernet 10/100Base-TX - RJ-45 , Audio / video
- Surge Suppression
- Surge Energy Rating
- 600 Joules
- Technology
- Lead Acid
- Run Time (Up To)
- Cables Included
- Network cable - external , Power cable - integrated - 2.44 m
- LED display, audible alarm
- FCC Class B certified, UL, cUL, FCC Part 68, IC
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 95%
- 22.5 cm
- 10.5 cm
- 37.2 cm
APC BackUPS 250/280/400 Replacement Battery Cartridge | In Stock | £59.45 |
