The Back-UPS CS provides professional-grade power protection for office and home office systems. Battery powered & surge protected power outlets, built-in phone/fax/modem line (DSL compatible) protection, safe system shutdown software with sophisticated power management features and pro-active audio-visual status indicators ensure office systems and their valuable data are protected from dangerous power surges, spikes and blackouts. USB connectivity gives users more flexibility making installation quicker and easier. Easy access to a hot-swappable, user-replaceable battery also makes servicing the Back-UPS CS hassle-free. These features along with its classic styling make the Back-UPS CS a perfect choice for protecting your important office and home office systems.
Serial connectivity
Provides management of the UPS via a serial port -
USB connectivity
Provides management of the UPS via a USB port (not available on all models)
- APC Back-UPS CS 350 - UPS - 210 Watt - 350 VA
- UPS - external
- 6.3 kg
- Load Rating
- Individual PC
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 210 Watt / 350 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 1 x power IEC 60320 C13 (surge) , 3 x power IEC 60320 C13 (UPS and surge)
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Batteries Qty
- 1
- Run Time (Up To)
- 4.7 min at full load
- Networking
- RS-232, USB
- Beige
- 9.1 cm x 28.4 cm x 16.5 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Plug-in module
- Beige
- Load Rating
- Individual PC
- Supported Battery Technology
- Lead Acid
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 196 - 280 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Power Capacity
- 210 Watt / 350 VA
- Dataline Surge Protection
- Phone line - RJ-45
- Surge Suppression
- Surge Energy Rating
- 300 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 6 hours
- Remote Management Interface
- RS-232, USB
- 1 x USB / serial RS-232 - RJ-45
- Cables Included
- USB cable - external
- Audible alarm
- C-Tick, GOST, UL 1449, VDE, EN 50091-2, EN 50091-1
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - replace or repair - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -15 °C
- Max Storage Temperature
- 45 °C
- 0 - 95%
- Humidity Range Storage
- 0 - 95%
- Sound Emission
- 40 dBA
- 9.1 cm
- 28.4 cm
- 16.5 cm
- 6.3 kg
- Shipping Width
- 24.1 cm
- Shipping Depth
- 36.8 cm
- Shipping Height
- 17.8 cm
- Shipping Weight
- 7.1 kg
APC BackUPS 250/280/400 Replacement Battery Cartridge | In Stock | £57.46 |
