APC Back-UPS 350Ei 350VA
Quicklinx: 11X1WS00 Mfr#: BK350EI
Type: UPS
Power Rating: 210watt
More than 50 In Stock
£113.65 ex VAT
£136.38 inc VAT
The Back-UPS CS provides professional-grade power protection for office and home office systems. Battery powered & surge protected power outlets, built-in phone/fax/modem line (DSL compatible) protection, safe system shutdown software with sophisticated power management features and pro-active audio-visual status indicators ensure office systems and their valuable data are protected from dangerous power surges, spikes and blackouts. USB connectivity gives users more flexibility making installation quicker and easier. Easy access to a hot-swappable, user-replaceable battery also makes servicing the Back-UPS CS hassle-free. These features along with its classic styling make the Back-UPS CS a perfect choice for protecting your important office and home office systems.
  • Serial connectivity
    Provides management of the UPS via a serial port
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models)
APC Back-UPS CS 350 - UPS - 210 watt - 350 VA
UPS - external
6.3 kg
Load Rating
Individual PC
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
210 watt / 350 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
1 x power IEC 60320 C13 (surge) , 3 x power IEC 60320 C13 (UPS and surge)
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
1
Run Time (Up To)
4.7 min at full load
RS-232, USB
Beige
9.1 cm x 28.4 cm x 16.5 cm
UPS - external
Battery Enclosure Type
Plug-in module
Beige
Load Rating
Individual PC
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Input Voltage Range
AC 196 - 280 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V
Power Capacity
210 watt / 350 VA
Dataline Surge Protection
Phone line - RJ-45
Surge Suppression
Surge Energy Rating
300 joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
6 hours
Remote Management Interface
RS-232, USB
1 x USB / serial RS-232 - RJ-45
USB cable - external
Audible alarm
C-Tick, GOST, UL 1449, VDE, EN 50091-2, EN 50091-1
Software Included
APC PowerChute Personal Edition
Limited warranty - replace or repair - 2 years
Min Storage Temperature
-15 °C
Max Storage Temperature
45 °C
0 - 95%
Humidity Range Storage
0 - 95%
Sound Emission
40 dBA
9.1 cm
28.4 cm
16.5 cm
6.3 kg
Shipping Width
24.1 cm
Shipping Depth
36.8 cm
Shipping Height
17.8 cm
Shipping Weight
7.1 kg
11X1 APC BackUPS 250/280/400 Replacement Battery Cartridge In Stock £60.80
Resources
The following resources are available for the APC Back-UPS 350Ei 350VA
Type: UPS
Brand: APC
