APC BACK-UPS 2200VA 230V AVR
Quicklinx: GCRGWS00 Mfr#: BX2200MI
Power Rating: 1200Watt
More than 50 In Stock
£209.49 ex VAT
£251.38 inc VAT
APC Back-UPS BX series is a cost-effective power protection solution for home and home office environments. The series comprehensive VA range with premium features further enables single UPS capabilities.
  • PowerChute Personal Edition OS Compatibility
    This software supports numerous operating systems and processors. lt/ /a gt/
  • Automatic Voltage Regulation (AVR)
    Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment.
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines.
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models).
APC Back-UPS BX Series BX2200MI - UPS - 1200 Watt - 2200 VA
UPS - external
12.3 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 10%
Power Capacity
1200 Watt / 2200 VA
Input Connectors
1 x power IEC 60320 C19
Output connectors
6 x power IEC 60320 C13
Lead Acid - 9 Ah
Batteries Qty
2
Run Time (Up To)
8.5 min at half load
14 cm x 39 cm x 19 cm
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 140 - 300 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 10% - 50/60 Hz
Power Capacity
1200 Watt / 2200 VA
Dataline Surge Protection
Network - RJ-45 - 1 input line / 1 output line
Output Waveform
Stepped approximation to a sinewave
Surge Energy Rating
273 Joules
Circuit Protection
Fuse
Quantity
2
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
8.5 min at 50% load , 1 min at full load
Recharge Time
8 hours
Transfer Time
6 ms
Maintenance free, sealed
1 x USB
Power cable - external - 1.2 m
Automatic Voltage Regulation (AVR), audible alarm
EN 62040-1, CB, IEC 62040-1, IEC 62040-2, IP20
Software Included
APC PowerChute Personal Edition
Limited warranty - replace or repair - 2 years
0 - 95%
14 cm
39 cm
19 cm
12.3 kg
Shipping Width
23.5 cm
Shipping Depth
49.5 cm
Shipping Height
29.7 cm
Shipping Weight
13.3 kg
Brand: APC
