APC Back-UPS BX series is a cost-effective power protection solution for home and home office environments. The comprehensive VA range with premium features further enables single UPS capabilities.
Automatic Voltage Regulation (AVR)
Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment. -
LED Indicators
Provide easy-to-read status of the unit and utility power conditions. -
PowerChute Personal Edition OS Compatibility
This software supports numerous operating systems and processors. /a -
USB connection
Use your PC to access additional power protection and management features for your UPS via a USB Port.
- APC Back-UPS BX Series BX1600MI - UPS - 900 watt - 1600 VA
- UPS - external
- 10.3 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 10%
- Power Capacity
- 900 watt / 1600 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 6 x power IEC 60320 C13
- Battery
- Lead Acid - 7 Ah
- Batteries Qty
- 2
- Run Time (Up To)
- 6.5 min at half load
- 14 cm x 39 cm x 19 cm
- 2-year warranty
- UPS - external
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 140 - 300 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 10% - 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network - RJ-45 - 1 input line / 1 output line
- Output Waveform
- Stepped approximation to a sinewave
- Surge Energy Rating
- 273 joules
- Circuit Protection
- Fuse
- Quantity
- 2
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 7 Ah
- Run Time (Up To)
- 6.5 min at 50% load , 1 min at full load
- Recharge Time
- 8 hours
- Transfer Time
- 6 ms
- Maintenance free, sealed
- 1 x USB
- Cables Included
- Power cable - external - 1.2 m
- Automatic Voltage Regulation (AVR), audible alarm
- EN 62040-1, CB, IEC 62040-1, IEC 62040-2, IP20
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - replace or repair - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 14 cm
- 39 cm
- 19 cm
- 10.3 kg
- Shipping Width
- 23.5 cm
- Shipping Depth
- 49.5 cm
- Shipping Height
- 29.7 cm
- Shipping Weight
- 11.3 kg
