APC Back-UPS 1400VA, 230V, AVR, IEC Sockets
Quicklinx: BW8HWS00 Mfr#: BX1400UI
APC's Back-UPS 1400 protect your electronic equipment from damage due to power outages, surges and spikes while providing short term battery power during an outage. The Back-UPS 1400 features Automatic Voltage Regulation (AVR), which instantly adjusts high and low voltage fluctuations to safe levels for your electronics, saving battery power for when you need it most during storms and power outages. Additionally, Australian sockets make for easy-to-use connection of protected equipment. Specifically designed to protect your PC equipment and network connection in harsh power environments, the Back-UPS 1400 ensures maximum productivity and work efficiency.
  • USB connection
    Use your PC to access additional power protection and management features for your UPS via a USB Port.
  • Telephone dataline surge protection
    Provides protection of connected equipment from power surges traveling on telephone lines.
  • Automatic Voltage Regulation (AVR)
    Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment.
  • Resettable circuit breaker
    Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs)
  • Automatic restart of loads after UPS shutdown
    Automatically starts up the connected equipment upon the return of utility power.
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
APC Back-UPS 1400VA - UPS - 700 watt - 1400 VA
UPS - external
12 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
700 watt / 1400 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13 (UPS and surge)
Lead Acid
Batteries Qty
1
Run Time (Up To)
2 min at full load
USB
13 cm x 33.6 cm x 21.5 cm
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 150 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
700 watt / 1400 VA
Dataline Surge Protection
Phone line - RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
273 joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
2 min at full load , 11 min at half load
Recharge Time
8 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B
Power cable 1.22 m
Audible alarm, audible alarm, Automatic Voltage Regulation (AVR), LED indicators, automatic self-test
C-Tick, IEC 62040-1-1, RoHS, A-Tick, REACH
Software Included
APC PowerChute Personal Edition
Limited warranty - replace or repair - 2 years
0 - 95%
Sound Emission
45 dBA
13 cm
33.6 cm
21.5 cm
12 kg
Shipping Width
24.5 cm
Shipping Depth
44 cm
Shipping Height
29.5 cm
Shipping Weight
12.94 kg
BW8H APC Service Pack 1 Year Warranty Extension In Stock £49.20
BW8H APC Service Pack 3 Year Warranty Extension In Stock £108.71
