APC's Back-UPS 1400 protect your electronic equipment from damage due to power outages, surges and spikes while providing short term battery power during an outage. The Back-UPS 1400 features Automatic Voltage Regulation (AVR), which instantly adjusts high and low voltage fluctuations to safe levels for your electronics, saving battery power for when you need it most during storms and power outages. Additionally, Australian sockets make for easy-to-use connection of protected equipment. Specifically designed to protect your PC equipment and network connection in harsh power environments, the Back-UPS 1400 ensures maximum productivity and work efficiency.
USB connection
Use your PC to access additional power protection and management features for your UPS via a USB Port. -
Telephone dataline surge protection
Provides protection of connected equipment from power surges traveling on telephone lines. -
Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment. -
Resettable circuit breaker
Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs) -
Automatic restart of loads after UPS shutdown
Automatically starts up the connected equipment upon the return of utility power. -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced.
- APC Back-UPS 1400VA - UPS - 700 Watt - 1400 VA
- UPS - external
- 12 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 700 Watt / 1400 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 6 x power IEC 60320 C13 (UPS and surge)
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 2 min at full load
- Networking
- USB
- Black
- 13 cm x 33.6 cm x 21.5 cm
- 2-year warranty
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 150 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Phone line - RJ-11
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 273 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 2 min at full load , 11 min at half load
- Recharge Time
- 8 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- USB
- 1 x management (USB) - 4 pin USB Type B
- Cables Included
- Power cable 1.22 m
- Audible alarm, audible alarm, Automatic Voltage Regulation (AVR), LED indicators, automatic self-test
- C-Tick, IEC 62040-1-1, RoHS, A-Tick, REACH
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - replace or repair - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 13 cm
- 33.6 cm
- 21.5 cm
- 12 kg
- Shipping Width
- 24.5 cm
- Shipping Depth
- 44 cm
- Shipping Height
- 29.5 cm
- Shipping Weight
- 12.94 kg
APC Service Pack 1 Year Warranty Extension | In Stock | £49.20 |
APC Service Pack 3 Year Warranty Extension | In Stock | £107.81 |
