This easily installed grille allows conditioned air from outside the room to enter into the closet. It is designed to meet the airflow requirements of the Wiring Closet Ventilation Unit.
- APC - air intake grille
- Product Type
- Air intake grille
- Placing / Mounting
- Ceiling mountable, wall mountable
- White
- 43.4 cm x 17.8 cm x 32.5 cm
- 6.5 kg
- 2-year warranty
- Product Type
- Air intake grille
- 43.4 cm
- 17.8 cm
- 32.5 cm
- 6.5 kg
- White
- Limited warranty: - 2 years
