Airflow Management Blanking Panels promote proper airflow within a rack enclosure by occupying unused space. Schneider Electric offers several varieties for differing rack management requirements. Modular toolless blanking panels allow for quick and easy installation into any EIA-310 19 inch rack or enclosure with square mounting holes. Metallic blanking panels are for threaded rail applications. Brush strips provide a barrier to airflow, while allowing cables to be passed from the front to the rear of the rack.
Promotes Proper Airflow
Helps to maintain proper rack temperatures within the enclosure by promoting top to bottom airflow movement -
Occupies 1U of rack space
Conserve valuable rack space in the data center
- APC Modular Toolless Blanking Panel - rack blanking panel kit - 1U
- Product Type
- Rack blanking panel kit
- Packaged Quantity
- 200 (specifications are for single item)
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- 48.3 cm x 0.3 cm x 4.5 cm
- 2-year warranty
- Designed For
- NetShelter SX
- Packaged Quantity
- Product Type
- Rack Size
- 19"
- 1U
- 48.3 cm
- 0.3 cm
- 4.5 cm
- Black
- EIA-310-D
- Limited warranty: - 2 years
- Designed For
- APC NetShelter SX
APC AP9520TH TEMP & HUMIDITY | In Stock | £256.99 |
